ytigi Çevrimdışı
ytigi
4 Nis 2019
516
Üstadım affınıza sığınarak full yazılım talep edebilme imkanım var mı? 🫣
Angelo89
9 Tem 2024
9
The software has been given to you to try, check the notification bell on the top right, the software link and installation description are written there. Apply it and write down the results.
Google Translate
He is alive, I thank him from the bottom of my heart, he is in good condition even though there is no Telefunken logo and Vestel is visible, many thanks from Romania, you are the best, keep it up. Helping those around you without asking for anything in return.
If you accept the risk, upload the label on the back of the TV here.
I'm glad your TV works with the software we provided. If you want, I can give you "TELEFENKEN" logo software.
Google translate
Evet sende telefunken logolu olan var, onu bana verebilirsin ben de montajını yaparım ama yine de philips için ona ihtiyacım var.
Kullanıcılar için gizli metin: Angelo89
1= Unzip the folder.
2= Copy the yellow folder named spi into an empty flash memory.
3= Insert the flash memory into the USB input port of the TV.
4= While the TV is running, press MENU 4 7 2 5 on the remote control.
5= In the menu that appears, scroll down to the usb operations line at the bottom and press OK. The software will be installed in 4-5 seconds.
6= After installation, exit with the menu button.
7= Turn off the TV with the remote control.
8= Restart after about 30 Seconds
9= Return the TV to the initial setup for the software to be active.
The responsibility is entirely yours.
Note: Unfortunately there is no software for PHILIPS television
