yokoono Çevrimiçi
Hi dear,
I tried, nothing with the arrows, but Led flashes quickly with my ok key. Unfortunately, nothing happens after several minutes. Thank you.
1. Use another stick
2. Use a stick of max. 4Gb
3. Try another USB plug
4. If the LED flashes quickly it means that the software is charging
5. Don't get impatient !. It can take up to 10 minutes.
Fritkot
4 Şub 2021
13
58
Thanks for your help.
I change my stick by a old 1Gb kingston datatraveler : Nothing with the file provided by jacobojacobo
I mistakenly used the file sent by By_trol (post 13596) and the TV start with a strange screen.
yokoono Çevrimiçi
If you enter the service menu (menu 4725) can you distinguish where the USB Operations option is? It's the last one downstairs.
bevibevi
28 Ocak 2021
Merhaba arkadaşlar. Resimdeki ürün için full yazılım gerekiyor. 17MB140 kart.
ilgilnene arkadaşa tşk ederim. Saygılar
Cihazdaki arıza Regla yazısı geliyor.sonra gidiyor. yazılım denedim ama full yazılım belki istiyor diye düşünüyorum.
Yada bios yazmak gerekiyorda olabilir. onun dosyasını bulamadım. 25l12835f bios chip kullanıyor
Fritkot
4 Şub 2021
13
58
I think it will be possible but now i can't access to the menu, I'm blocked on the language selection screen.
Si vous entrez dans le menu de service (menu 4725), pouvez-vous distinguer où se trouve l’option opérations USB ? C’est le dernier en bas.
kQue (en)
Ok, I'm in the menu. It was the wrong key on the remote control. Here is home. But it is not readble. Only few lines
at the top.
jacabojacabo Çevrimdışı
18 May 2019
335
kQue (en)
at the top.
Copy the screen file from the service menu to the flash drive and transfer it here.TV would turn on if you tried the recovery software a few times.you haven't tried
Fritkot
4 Şub 2021
13
58
I'm completely blind.
I checked:
0 push on the down arrow key: some alphabet choice
1 push on the down arrow key: Audio Surround
2 push on the down arrow key: Last state ...
3 push on the down arrow key: menu begining by disabled
4 push on the down arrow key: Menu with OLM, Yes ...
5 push on the down arrow key: stats
6 push on the down arrow key:Menu yes, no, no
7 push on the down arrow key: Menu ok, ..., ...
8 push on the down arrow key: Write a power_up.log on the usb key
9 push on the down arrow key: return to some alphabet choice
yokoono Çevrimiçi
kQue (en)
at the top.
1. Create a folder called downloadprofile.mb140 on the stick
2. Insert the stick into the usb
3. Type menu 4725 and navigate down to the last line (last line is USB Operations).
4. Type OK and wait 10 seconds
5. Exit the menu and turn off the TV. When the left LED stops flashing, remove the stick
6. Post the files on the stick here.
7. Delete and create a folder called downloadpq.mb140
8. Repeat as above
If someone has saved the panel profile it is easily solved. If not, post the saved files and jacabojacabo helps.
Hi The software is installed according to the barcode on the back cover of the television. You have installed the software I gave to another member in my correspondence.
Fritkot
4 Şub 2021
13
58
8. Repeat as above
Hi, I have the files. Many many thanks
There is a dropbox link:
I can't find the procedure via the forum
Linkteki yazılımı dener misin.
