Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canViewThreadWarningsMP is not callable on the given object (XF\Entity\User) (src/XF/Template/Templater.php:1295)
  • Template public:tckChangeContentOwner_macros: [E_USER_WARNING] Method canChangeOwner is not callable on the given object (XF\Entity\Thread) (src/XF/Template/Templater.php:1295)
  • Template public:tckChangeContentOwner_macros: [E_USER_WARNING] Method canChangeDate is not callable on the given object (XF\Entity\Thread) (src/XF/Template/Templater.php:1295)
  • Template public:ap_postbit: [E_USER_WARNING] Template public:ap_postbit is unknown (src/XF/Template/Templater.php:792)
  • Template public:tckChangeContentOwner_macros: [E_USER_WARNING] Method canChangeOwner is not callable on the given object (XF\Entity\Post) (src/XF/Template/Templater.php:1295)
  • Template public:tckChangeContentOwner_macros: [E_USER_WARNING] Method canChangeDate is not callable on the given object (XF\Entity\Post) (src/XF/Template/Templater.php:1295)
  • Template public:lightbox_macros: [E_USER_WARNING] Cannot call method getUrl on a non-object (NULL) (src/XF/Template/Templater.php:1285)
  • Template public:lightbox_macros: [E_USER_WARNING] Cannot call method getCss on a non-object (NULL) (src/XF/Template/Templater.php:1285)
  • Template public:lightbox_macros: [E_USER_WARNING] Cannot call method isNotScripBlockNeeded on a non-object (NULL) (src/XF/Template/Templater.php:1285)
  • Template :: [E_USER_WARNING] Method canViewResources is not callable on the given object (XF\Entity\User) (src/XF/Template/Templater.php:1295)
  • Template public:andrew_moderatorpanel_macros: [E_USER_WARNING] Template public:andrew_moderatorpanel_macros is unknown (src/XF/Template/Templater.php:792)
  • Template public:andrew_moderatorpanel_macros: [E_USER_WARNING] Macro public:andrew_moderatorpanel_macros:andrew_moderatorpanel_modlink is unknown (src/XF/Template/Templater.php:759)
  • Template public:PAGE_CONTAINER: [E_USER_WARNING] Method canGoogleSearch is not callable on the given object (XF\Entity\User) (src/XF/Template/Templater.php:1295)
  • Template public:xgt_forum_istatistik_konumlar: [E_USER_WARNING] Template public:xgt_forum_istatistik_konumlar is unknown (src/XF/Template/Templater.php:792)
  • Template public:xgt_forum_istatistik_konumlar: [E_USER_WARNING] Macro public:xgt_forum_istatistik_konumlar:xgtIstatistikKonum is unknown (src/XF/Template/Templater.php:759)
Herkese selamlar,
Bir süre TV araştırdıktan sonra 30 kasımda 12000TL fiyata LG 70nano756 modelini aldım. Piyasaya yeni çıkmış bir model. Özelliklerini araştırıp, teşhirde görmeden sipariş verdim. Forumdaki arkadaşlara yardımcı olması dileğiyle düşüncelerimi paylaşıyorum, çünkü bu modeli muhtemelen ilk kullanan benim. Geçen hafta kurulumu yapıldı.
70inç, VA panel, Direct Led, 50hz, WebOS işletim sistemi ve programları mevcut, HDR 10 pro ve HLG destekli, 10+10w ses kalitesi fena değil, akıllı kumandası kullanışlı, Türkçe sesli komut mevcut, ekran yansıtma, Bluetooth 5.0, üç adet Hdmi 2.0, 4 çekirdek işlemcili bir model.
Uydu yayını, YouTube, Netflix yayınlarında görüntü ve ses kalitesinden memnunum. 70 inç olması sinema keyfi yaşatıyor. Zaten düşüncem Nanocell destekli bir VA panelin göz zevkime hitap edeceğiydi ve akıllı kumanda özelliği hoşuma gidiyordu. 65inç ve üstü bir TV istiyordum. Fiyatların coştuğu bu dönemde bütçem buna yetti.
70nano756 teknik olarak giriş seviyesi bir televizyon olması itibariyle ön plana çıkan bir özelliği yok. Ancak sinema seven biri olarak keşke Dolby Vision özelliği de olsaydı diyorum. Smart özellikleri seri şekilde kullanılabiliyor ama oturduğum sitede ortak anten kullanılmasından mıdır bilemedim kanal geçişleri bana yavaş geldi. Hdmi 2.1 de olmasını isterdim.
Malum bütçe problemi olan arkadaşlar için kişisel bir fikrimi beyan isterim; akrabalarımda Toshiba, Vestel, Hi-Level televizyonlar var, görüntü kalitesi olarak aldığım televizyonun onlardan bariz bi fark göremedim. Panel türünün avantaj ve dezavantajlarını bilerek Yerli bi marka da alsam pişman olmazmışım. Bence yerli markalar belli bi kaliteyi yakalamış.
TV almayı düşünen arkadaşlar; teknik özelliklerinin kendi göz zevkinize ve kullanım şeklinize uygunluğuna karar vermeniz çok önemli.
Gündüz vakti kurulum yapılırken gözüme ölü piksel, vertikal band, ışık sızması, bulutlanma takılmadı.
Antakya'da tek yetkili servis var, Ustaya bu testleri sorduğumda; ''Ben göreceğim şeyleri görüyorum'' dedi. :hmmyani?!?
İyi mi diyor kötü mü diyor anlamadım:ara Zaten servis personeli evde çok kalmıyor, diğer işlerine yetişmeye çalışıyor. Emek sahiplerinin eline sağlık ?
Ancak akşam karanlıkta bulutlanma için test videosu açtığım da orta seviye bulutlanma ve sol alt köşede hafifçe bir ışık sızması gördüm.
Fotoğraf çekince belki kamera kaynaklı çirkin bir görüntü çıksa da Bu durum film izlerken açık ve karanlık sahnelerde hafif belirgin seviyede. Sonuç olarak bu durum normal midir, ilerde problem çıkarma olasılığı yüksek midir, servise başvurmalı mıyım?
İzlenecek yol hususunda tavsiyelerinizi bekliyorum @Unforgotten @Winston @Adem Helvacı
Not: Bahsettiğim televizyonla ilgili sorularınız olursa bilgim yettiği kadar cevaplayabilirim, forum ailesine teşekkürler.
Arkadaşlar Samsung 55AU7200 55'' sipariş vermek üzereyim ama çok arada kaldım Tizen TV hakkında. Tarayıcıya güncelleme gelmediği için sitelere girmediğini ve uygulamaları kısıtlı olduğu yorumlarını okuyorum. TV'den beklentilerim uzun süreli kullanımda sorun çıkarmayacak, interneti ve uygulamaları (Netflix, Twitch ve YouTube vb.) Sorunsuz kullanmak. Güncel kullananlar aydınlatabilirse çok iyi olur yoksa diğer Vestel TV'yi(Vestel 65U9500 65'')
alacağım sanırım. Ya da beklentilerimi karşılayacak max 8500 TL önerileriniz varsa bekliyorum.
Benim bir önceki televizyonum Samsung idi (sanırım modeli H6470) ... forumda daha tecrübeli üstadlar olduğu için sadece kendi deneyimimi paylaşıp, baktığınız model ile ilgili ahkam kesmeyeceğim.
Televizyonu kullandığım son güne kadar Netflix, Youtube ve Spotify gibi uygulamları mevcut sürümleriyle sorunsuz kullandım... tabi benimki biraz eski bir model ... işlemci kapasitesi bu gün itibariyle çok yüksek değildir (lakin aldığım vakit çok iyiydi) .. bu uygulamaları çalışırken sorun yok .. uygulamlar üzerinde gezerken de yeterince akıcıydı (yeterince diyorum.. öyle akıp gitmiyor yeni TV ler gibi) ... Browser vasat... aldığım ilk seneler de bir kaç kez browser üzerinden film izlemişliğim oldu .. ama sonra heralde destek ve güncelleme eksikliği ile o filmler aynı sitler de çalışmaz oldu ...
Şu anki Tizenler muhtemelen daha akıcı ve daha iyi bir browser ile geliyorlardır.. ama güncelleme konusu bir yere kadar.. bir kaç yıl sonra güncelleme almayabilirler. Bu konuda belki Android / Google TV ler daha güncel kalıp daha fazla uygulama alternatifi ile durumu idare edebilirler..
Kısacası, uygulamlarda (browser hariç) hiç bir sorun yaşamadım 4-5 yıl boyunca.. ama güncelleme almayı 1-2 yıl sonra bıraktı televizyon.
@zedayden, Ben de @atoprak ile aynı fikirdeyim. Evde 2. tv olarak 2014 yılında aldığım Samsung UE40H6470 kullanıyorum. Netflix, Amazon Prime, Youtube vb. bütün uygulamalar halen sorunsuz çalışıyor ve aktif olarak kullanıyorum. Yalnız Exxen desteği gelmedi henüz, gelir mi bilemiyorum.
Eğer Samsung'tan sırf işletim sistemi nedeniyle vazgeçecekseniz bu konuda bence yanlış düşünüyorsunuz. Tarayıcı konusunda da yanlış düşünüyorsunuz. Tarayıcı üzerinden TV seyretmek pek mantıklı bir hareket değil. Sonuçta bu bir televizyon, bilgisayar değil.
IOS haricinde bütün işletim sistemleri belli bir süre sonra yavaşlamaya mahkumdur bence. Webos, Tizen, Android fark etmez. Alacağınız tv'de önce panel kalitesine ve görüntü teknolojilerine bakın. Gerisi detaylara kalmış. Dandik panel kullandıktan ve görüntü kalitesi kötü olduktan sonra Intel I9 12900K işlemcisi olsa ne olur ? Bana öncelikle tarayıcısı hızlı çalışan tv değil en iyi görüntüyü sunan tv gerekli.
Diğer yandan, Samsung'ta kullanılan bileşenlerin kalitesi ile Vestel'de kullanılan bileşenlerin kalitesi arasında bence fark olur. Bugün çoğu yerli üretim tv'lerin ram bellekleri 1,5 GB.
Herkese selamlar,
Fotoğraf çekince belki kamera kaynaklı çirkin bir görüntü çıksa da Bu durum film izlerken açık ve karanlık sahnelerde fark edilmeyecek veya rahatsız olmadığım seviyede. Sonuç olarak bu durum normal midir, ilerde problem çıkarma olasılığı yüksek midir, servise başvurmalı mıyım?
Akrabalarınızdaki Toshiba, Vestel, Hi-Level marka televizyonlarda muhtemelen sadece uydu yayını izlediğiniz için, arada fark görmemeniz doğal. Eğer yanlış biliyorsam teknik konulara haiz olan arkadaşlar beni uyarsın; NanoCell'in olayı zengin renkler sunması fakat sadece HDR içeriklerde avantaj sağlar.
Kanal geçişlerine çok takılmayın bence, görüntü kalitesi en ön planda olmalı. Görüntüden memnunsanız varsın yavaş olsun, harici bir uydu alıcı ile çözersiniz.
Televizyonunuz Dolby Vision desteklese de çok bir şey değişmezdi. Dolby Vision'un farkı, dinamik resim karesi işlemesinin yanında 4.000 nit'e kadar parlaklık standardına sahip olması. Sahip olduğunuz tv'nin parlaklık değerlerine ulaşamadım fakat tahminim 350 nits'ten yukarıda olmadığı yönünde. Panel parlaklığı sınırlı olduğu için Dolby Vision'ı bırakın HDR performansı dahi tartışılır.
TV'yi kurmaya gelen arkadaş sizinle ilgilenmek istemediği için öyle bir cevap vermiş. Bulutlanma ve ışık sızması sizi rahatsız etmiyorsa bence sorun olmaz. Değiştirme olayına girerseniz hem zahmetli olacak hem de yerine gelecek televizyonun daha kötü çıkma ihtimali var, gelen gideni aratır misali.
Aynen, misafirliğe gidince uydu yayını izliyoruz. Benim televizyonda farklı filmler izledikçe bulutlanma ve ışık sızması fark edilir oldu, ama filme odaklanıp çok kafaya takmamak en iyisi gibi. Dediğiniz gibi ileri derece bi kusur olmadıkça ürün değişim işlemleri müşteriye eziyete dönüşüyor, yeni gelen ürün de muamma...
Bu TV piyasasında bu paraya bu kalite ?
Herkese selamlar,
Bende aynısını 30 kasımda aldım. İki gün sonra
Herkese selamlar,
Bende kasımda aynısından aldım. Test yaptım youtubeden. Bende ölü piksel çıktı. Ardından verical banding banding bariz belli oluyor.
Philips'te de tıpkı LG ve Sony'de olduğu gibi, led tv sınıfında 9 serisi en iyileri oluyor diye biliyorum. Lakin fiyat olarak pahalı olurlar. Philips 9 serisi yerine şahsen Sony 9 tercih ederim. 2017 model Sony ile 2021 model Philips 9206 arasındaki fark oldukça ciddi görünüyor.
Template public:_media_site_embed_youtube not found. Try rebuilding or reinstalling the s9e/MediaSites add-on.
Kusura bakmayın, panel hakkında sorduğum için soruyu yanlış yere yazdığımı sanıp silmiş bulundum. Soruyu başlık olarak açmıştım tam da.
aslında tavsiyeler üzerine lg nano916 serisi de hoşuma gitmişti. Sony televizyon da güzel duruyor. Sanırım 90j modelini diyorsunuz. Ama nedense amblight olayından vazgeçemedim. Normalde 75" bakıyordum ama o önerilen modellerin 75" olanları benim bütçemi aşacak. 65"e düşmüşken de en azından amblight olandan alayım, ekran daha büyük hissettirir dedim.
Merhabalar. Biraz arattim forumda ama net bir cevap alamadim . 65 ul 2163 dt toshiba tvyi a101 den almak istiyorum. Daha once 58 inc panda va paneli aldim. @fikoloji o zaman cok aydinlatici olmustu sagolsun. iki yil oldu kullaniyorummemnunum. Simdi de toshiba alalim dedim ailem icin. Buyuk bir salona buyuk olsun diye bu tvyi sectik. BOE uretimi ips ekran tatmin edici olur mu. Vestel uretimi ortasinif bir urun aldigimin farkindayim cok kotu olmaz diye düşünüyorum. Kullanicisi olan arkadaslar var mi? Va panel bana iyi geliyor ips cok dusuk goruntu verir mi?
TV tavsiyesi vermiyorum ama yorum olarak ;
Gerçekten 58ul3a63dt nin yeri bende ayrıdır. TV hantaldir ama görüntü işlemcisi ana kartta sağlamdır. Panel olarak ortama bir panel olan chot veya panda gelmekte buna rağmen mb230 ana kart panda veya chota göre çok daha iyidir.
65ul2163dt ise ana kart olarak 130 yerini tutmasa da mb230 dan çok daha iyi geliyor bana. Panel ise boe IPS panel pandadan çok daha iyi ama ekran büyüdükçe görüntü kalitesi düşmektedir.
Ben 2 konuya değinmek isterim avantaj ve dezavantajları mevcut birinde panel olarak boe iyi diğerinde ana kart olarak mb130 iyi.
Sizi uzecegini sanmam şimdiden hayırlı olsun
Cok teşekkür ederim cevap icin? en buyuk kaygim paneldi. Fiyat performans acisindan urun iyi geliyor bana. Yorumun da yardimci oldu eyvallah?
Philips in 9206 modelide parlaklığı 8506 modeliyle aynı.
9206. 100hz
8506. 50 hz
Panel kullanırlar.
Mva panel Va nin varyantlari olur.
Pva
Amva
Smva
Hva vb..
Estağfirullah. Canlı renkler istiyorsanız ve yan açılardan izleyecekseniz IPS panel seçin. Televizyonu tam karşıdan izleyecekseniz, kontrast yüksek ve siyahlar derin olsun istiyorsanız VA panel tercih edin.
LG markasının hiç bir led televizyonu Samsung ve Sony'nin 9 serisi televizyonları ile yarışacak düzeyde değil çünkü onlar Oled'e ağırlık veriyorlar.
Benim önereceğim televizyonlar;
Sony 65X90J, 65XH9096 - XH9077
Samsung Q90T, Q95T, Q80T
Tabi Sony veya Samsung alırsanız bu 100% sorun yaşamayacağınız anlamına gelmiyor, bu biraz şans işi. Siz Ambilight'ın büyüsüne kapılıp Philips alacaksınız sanırım. Gönlünüz nereye kayıyorsa onu tercih edin ☺️
Reddit, AVForums gibi yerlerde araştırma yapmanızı öneririm.
