yokoono Çevrimdışı
Teşekkür ederim efendim, bu DVB_T2 ile ilgili sorunu çözmedi, başka seçenekler var mı?
1. On the original board (17MB97) DOES DVB-T2 WORK?
2. In my country, DVB-T2 is not used, so I was not interested. And neither is DVB-S.
3. Save the TV profile to the stick and see what you find. SWProfile = PatentItems = DVBT2 = DVBT2 = TRUE
You can also post a picture of MENU 4725.
MSmaster7000
17 Şub 2025
10
63
maxphone
6 Haz 2025
Hello, guys! Sorry, I don't speak your language. 🙁
Someone replaced the mainboard in this TV. It was working well, but when I launched the built-in YouTube app, stripes would appear, the TV would freeze and then reboot. I flashed the first firmware I could find with a similar panel — from a Daewoo 55DM54UA (17MB170, VES550QNDH-N2). Now the image is doubled and stretched. Please help me with the correct file if possible! 😊 +It doesn't enter the service menu (menu4725)
yokoono Çevrimdışı
In the profile saved from the TV, there is NO DVB-T2 function. I don't know what software was rewritten. I have a profile saved from 17MB97 with this function active. You can copy swprofile to the TV. At your own risk.
Unzip. Folder on stick. USB Operations/ ok. Turn off the TV and turn it on when the STBY LED stops blinking.
yokoono Çevrimdışı
I don't have anything in the archive that can help you.
V Çevrimdışı
VaviŞ
12 Şub 2021
6
47
Selam. Vestel 32HB5000 televizyonum açılmıyor kendi kendine reset atıyor. Kurtarma yazılımı talep edebilir miyim
maxphone
6 Haz 2025
Ok, thank you!
Another update — I found an old mainboard! With it, the TV does boot up, but the buttons almost don’t respond, I can’t access the menu or the service menu, and it behaves poorly. It constantly shows the message: “Memory full.”
If you remember, for Chinese mainboards there used to be a small file — around 17KB — that would force the TV into recovery mode and perform a hard reset.
Is there something similar available for our platform? Thanks! :)
socoka
30 Eki 2020
Merhaba!
Ne yazık ki televizyon uzaktan kumandaya yanıt vermiyor!
Kurtarma yazılımına ihtiyacım var.
Çok teşekkür ederim!
yokoono Çevrimdışı
Merhaba!
"Ne yazık ki televizyon uzaktan kumandaya yanıt vermiyor!"
How do you install the software if the remote control is inactive? You need the OK key on the remote control.
socoka
30 Eki 2020
Televizyon uzaktan kumandayı algılıyor ancak işlemi gerçekleştirmiyor!
Bekleme LED'i yanıp sönmeye devam ediyor!
Tam yazılıma ihtiyacım var!
