I Çevrimdışı
ilyakov35
22 Kas 2020
CİHAZda seg yazısı geliyor ve sonra tekrar kapanıyor.... 3 ayrı flash bellekle MB140 yazılımı denedim ama herhangi bir işlem olmadı
yokoono Çevrimdışı
hello to all
my tv is bricked it powrs up shows the logo and then goes to black screen
any way to fix it, the pick is before the upgrade
it is mb130 v5
FL2D4903UH
17MB130
firmware V.5.35.2.0
this happent after factory reset
i cant go to menu 4725 now only this way let me do it
SOFTWARE UPDATE
MAIN SOFTWARE UPDATE
1. mb130_en.bin, mb130_RomBoot.bin, mb130_PM51.bin and usb_auto_update_G10.txt documents should
be copied directly inside of a flash memory (not in a folder).
2. Insert flash memory to the TV when TV is powered off.
3. While pushing the OK button in remote control, power on and wait. TV will power-up itself.
4. If First Time Installation screen comes, it means software update procedure is successful.
but i dont have the files
thank you all
For 17mb130s
BETA ELEKTRONİK
4 Mar 2020
39
ARKADAŞLAR MERHABA HERKESE KOLAY GELSİN VESTEL 32 17MB140 FULL YAZILIMA İHTİYACIM VAR YARDIMCI OLABİLİR MİSİNİZ ŞİMDİDEN TEŞEKKÜRLER.
