Здравствуйте, помогите найти программное обеспечение для телевизор DAEWOO D65DM54UANS, МАТЕРИНСКАЯ ПЛАТА vestel 17MB185 (180721R2A), матрица VES650QNTL-N2-N42. Телевизор включается, но постоянно находится в загрузке "android tv". Буду очень признателен если поможете.
Sadece TÜRKÇE ya da İNGİLİZCE dillerinde yazabilirsiniz. İçeriği düzeltin.
I have nothing in the archive to help you.
1. I do not give authorization
2. The software on this website is valid for televisions sold in Turkey.
3. Does it bother you that it works with a different remote control or the logo that it is Vestel instead of Hitachi?.
4. I use the software for debugging, not for updating. The owner is responsible for the update.
1. Who can help me with getting software for Hitachi. It is on the server, who provides the authorization? I'm sorry, but Mr. Sota referred me to you, so I turned to you for help.
2. And if the TV is exported from Turkey to Europe, does it already lose your support? Why are there so many languages in the menu, if the TV is for the domestic market?
3. What bothers me the most is that it works with a different remote control and the Vestel logo instead of Hitachi. Thanks to the software provided by you, it was possible to restore its performance, I would also like to restore the brand and remote control.
4. Responsibility and all risks for updates are borne by the owner - that's clear, but if you have any other software options for Hitachi, I would like to try, even for another matrix, because I have the files for my matrix. At your own risk.
thank you
Kurtarma yazılımı verildi. Detaylar için imzama bakın.
Not: Nick' inizi değiştirme için en kısa sürede başvuruda bulunun. Yoksa anlamsız harf dizileriyle nicklere izin vermiyoruz, uzaklaştırılırsınız.
Nick başvurusu yaptım fakat imzaya bakmak nasıl oluyor ben bir seçenek bulamadım
İmza içeriğini kopyaladım;
Mesajlara tepki verilmediği taktirde cevap verilmeyecektir.
Kurallar okunmadan, yanlış konuya, rastgele, yeni konu açarak yapılan yazılım isteklerine KESİNLİKLE yanıt verilmeyecektir!
Yazılım istekleri için;
Konunun ilk mesajını OKUYUN! Gereken bilgileri GÖRSEL olarak paylaşın. TV' deki problemi detaylı olarak yazın.
Yazılım verildiğinde; Sağ üstte çan simgesinden bildirimleri kontrol edin. Yükleme talimatı indirme sayfasındadır. Yükleme sonucunu MUTLAKA yazın.
Merhabalar
32HL530 model Hi level marka televizyonum açılmıyor. ışık yanıp sönüyor yayın gelmiyor. daha önce de böyle olmuştu garantisi devam ediyoken servis çağırmıştım yazılım atıp düzeltmişti. yazılım indirmek istiyorum. anakartta vs. de herangi bir değişiklik olmadı tamire gitmedi sadece evde servis tarafından yazılım atıldı.
Merhabalar
Full yazılım verildi. Detaylar için imzama bakın.
thank you
1. The remote control code can be changed with the profile in this TV model. I do not have.
2. You can change the logo with the spi profile saved from this TV model. I do not have.
3. You can cancel the logo so that the TV will start without the logo.
4. You can rewrite the flash memory. You need a programmer. I have bin for the programmer.
Merhabalar, Regal yazısı gelip kayboluyordu sureklı ac kapa yapıldıgında belli belirsiz sinyal yok yazısı olduğundan yazılım güncelleştirmesi yaptım koduna uygun olanı ile ama suanda kırmızı ısık sabit yanıyor ve herhangi bi yazılım veya tepki alamıyorum yardımcı olabilir misiniz? Yanlıs yazılımı üzerindeki entegre ile düzeltebilir miyim yazılım yukleme cihazına sahibim dumb dosyalarını bulma sansımız var mı ?
Teşekkür ederim indirdim, flashı fat32 ile biçimlendirip içine attım. söylenilen adımları uyguladım ama tepki alamadım. sorun çözülmedi herhangi bir değişiklik olmadı. rar ın içinde 3 adet dosya var birisi not defteri olmak üzere 3 ünü de mi flasha atmalıyım yoksa mb140.en dosyasını mı sadece atmalıyım?
