MarioB2B
8 Nis 2019
6
M MarioB2B,
Unfortunately, we are unable to access the information since it is an exported device. If you see your business mb90 link to give mboot try.
Thanks for your answer
It's sad to hear that.
I test the version, but the picture is reversed (but the color is better :alala).
I Forgot an important information (maybe).
The chassis is a Vestel VES550UNES-2D-S01.
Very thanks
23,484
Nop, you haven't this programmer
I have dumped, with little programmer, the content inside the SPI flash (U10) before all.
I tried to communicate with the console to launch manually a command on the U-BOOT or the linux.
But the nandflash is corrupted and the boot stopped with died services and the linux inside the board reboot systematicly.
Impossible to launch an USBOPERATIONS command to donwload the "hwprofile" or others files.
I have install a firmware 338c but i have a black screen or i have a reverse picture (incorrect EDID setting i think, it's not firmware for this model).
Thanks
Tv modeli nedir ?
23,484
Very thanks
47PF9090 -338c benim tv yazılımıdır,veya edit dosyasını da vereyim dene bakalım :ok
MarioB2B
8 Nis 2019
6
M MarioB2B
Edit.edit
Hello,
Thanks.
That don't work ... But that help me !!
The edid is correct on spi flash u10, and is correct (ves 55" FHD-LCD) but the panel setting is wrong.
I found that chassis is similar to the TELEFUNKEN L55F243N3C.
This model has same panel, same mainboard, and I found all profile files on another forum (by chance?? :affet).
It's very late to test this today.
I think that better is a full recovery with a 338c firmware for another model (but for mb91-2 mainboard) and relaoding the profile for ves550unes chassis on usb, with USBOPERATIONS command on terminal if I have a black screen ... I can dream if that works !! :gul
I see tomorrow to test that.
If I can and, if that works, I will send this profile files, if that can help anyone.
Thanks and good night
23,484
Hello,
Thanks.
Hımm,saat :03:50 :)
birde 55'' vestel 362j vereyim,yine kendi kullandığım ve edid.edid verdiğim full yazılım,umarım işe yarar,madem yarın bakarsın sevgili MarioB2B :ok
Buyrun Hocam çok eşekkür ederim ilgi ve alakanıza
full yazılımınız:
full yazılım yükleme anlatımı için Tıklayınız
MarioB2B
8 Nis 2019
6
Hello everybody !
Wonderfull, that's work ! :clap
Hımm,saat :03:50 :)
But I just tried with the firmware 338c for mb91 (i dont test with another version at this time).
Can help these profiles
Yes :clap2, it's the package that i was talking yesterday, that i found on another forum.
In fact, the configuration files for the panel and etc, is the "pq" package.
I put the "profile" "pq" folder (no "spi" because my flash spi was ok) and that's done !
I found the correct setting for my panel Vestel VES550UNES-2D-S01 !!
I don't know the "pq" file. It's obtain with the file downloadpq.md90, for my board (as downloadpq.mdxx) ...
Wow
Very thanks for your help, dudes !! :ok
Best regards
yokoono Çevrimiçi
Hello everybody !
Wow
Best regards
I'm glad you did it and it's okay.
Greetings from Romania.
