- 20 Mar 2019
- 3,063
- 74
After copying the profile to the TV:The motherboard is dead.So I put another motherboard.İt is 17MB-96.But the screen is Negative.I try this solution:'Panels with cards between MB90-MB96: VESTEL_D1_Plus_PNL.bin file will be edited. If line 9880 is 0, set it to 1, if it is 1, set it to 0 If line 9932 is 0, set it to 1, if it is 1, set it to 0, or you can find these two lines by experimenting.' But the panel has been not fixed.Do you have repair method?
1. Exit SM
2. Turn off the TV from the remote control
3. The stby LED on the TV flashes. Wait until it becomes solid.
4. Unplug the TV
5. Wait until the stby LED goes out.
6. Turn on the TV and when it's ok, remove the stick.
If there is no change, repeat the operation or try with a very small capacity stick.
