- 20 Mar 2019
- 3,425
- 74
Cod panel (VES400xxx-xx-xx) ???.Arkadaşlar. Vestel 17mb110s anakar degiştim p nelle uyum saglamadı resim ters bana panel yazılımı lazım
panel yazılımını verdimCod panel (VES400xxx-xx-xx) ???.
Panel profile17mb140 yeni kart takıldı fakat ekran ters duruyor panel yazılımı gerekli
1. Save the panel profile and post it hereDear All I have tv Telefunken 55fb5000 with defect main 17mb211.I have changed to 17mb140 but panelsoft does not match.If someone can help for panel software ves 550undl-2d-n11 for 17mb140
Dear YokoNice to hear from You. Due to polaraztion of colors can not be seen nothing of menu 4725 What you want to see there may I help You?1. Save the panel profile and post it here
2. Put a picture of MENU 4725.
Modified profile. Try at your own risk.Dear YokoNice to hear from You. Due to polaraztion of colors can not be seen nothing of menu 4725 What you want to see there may I help You?Ziyaretçiler için gizlenmiş link,görmek için Giriş yap veya üye ol.
Thank you Yoko i have loaded the profile but the colors are green and purple (no red color) Tomorrow will make picture of service menu(now is visible.17mb140 is taken from 48 inch tv with panel ves 480unds-2d-n12. i suspect that all soft must be replaced with the right one for 55 inchModified profile. Try at your own risk.
Cod main (17MBxxx) ???.![]()
Merhaba elinizde panel dosyası var mı?
Model:VES490UNDS-2D-N13
23364586
Yes,17MB96Cod main (17MBxxx) ???.
For 17MB96 and VES490UNDS-2D-N13 panel, I don't have a panel profile.Yes,17MB96
The motherboard is dead.So I put another motherboard.İt is 17MB-96.But the screen is Negative.I try this solution:'Panels with cards between MB90-MB96: VESTEL_D1_Plus_PNL.bin file will be edited. If line 9880 is 0, set it to 1, if it is 1, set it to 0 If line 9932 is 0, set it to 1, if it is 1, set it to 0, or you can find these two lines by experimenting.' But the panel has been not fixed.Do you have repair method?For 17MB96 and VES490UNDS-2D-N13 panel, I don't have a panel profile.
1. What problem does the image have?
2. Save the panel profile from the TV and post it here.
