teşekkür ederim
Merhaba bozuk olan ve yeni takılan kart 17mb82 resimde titreme sorunu yardımcı olur
sanız sevinirim
Öncelikle arızalı görüntüyü paylaşın. Görüntüdeki problemin ne olduğunu görmeden panel dosyasında işlem yapılamaz.
HELLO. I have a Hitachi TV with a 17MB95M motherboard and a VES400UNDS-N01 panel. Because the Smart function is not active for me, I replaced 17MB95M with 17MB110P. The image has a red tint with a slight tremor vertically. Any panel profile I try does not bring any improvement. How do I solve that red color?.
Master, you know better, but could there be a problem with the T_CON card? As you know, panel problems usually appear as mirror or rgb color problems. Shall we try to edit the panel file regarding the color problem?
1. It has t-cone
2. With the original 17mb95 board it works perfectly
3. With another soft full the colors do not return to normal
4. I don't have exact panel profile for mb110p and ves400unds-n01 panel
5. With any panel profile I tried, the red color persisted
6. This is how the panel profile saved from the TV looks
1. It has t-cone
My guess is it's a problem with the color chart. However, we have fixed the negative pattern issue with the color part in the profiles we have manipulated so far. I saw the color line marked as "1" in the panel profile you sent. I changed it to "0" and sent it. However, if this profile reverses the negative pattern and completely removes the red color, a completely different problem may arise. If you still want to try, below;
I also wonder if it can solve a regulation problem that may be caused by LVDS sockets.
Good morning. I tried. The only change is that the image is upside down. The red color remains.
Now it has Finlux software.
I also rewrote the Toshiba software and the image did not return to normal.
Good morning. I can modified the file again. This modification is fixed mirror image and (I think) fixed color error.
Now it looks like this
I expected it to be like this. I was even suspecting that the image was completely gone. Unfortunately, that's all we can edit with my current knowledge. I am posting the original TMG file below. Since the color problem is not gone, the negative pattern problem will also disappear with this.
I think this 17MB110P and VES400UNDS-N01 panel combination has never been used. In addition, I did not find anything about this panel on google. It's like it wasn't even manufactured. I suspect that it can be fixed with some changes to the lvds routes. I do not do that. Thank you for help. Health to all.
I think the same thing. In my previous message, I thought and said something similar about lvds.
However, it is very difficult to work with flat cables and it is not possible because you have to go through the scheme one by one. It is already not possible as we could not find information about the panel.
You're wellcome. I wish we had something. Health to you. 😍
yokoono i think this is 8bit/10bit problem. send me tcon code and picture of mb110 via pm
Thank you for your interest, but I gave up on the modification. I also have problems with my eyes. I will take this issue into account in a future modification.
What's up with your website?
