yokoono Çevrimdışı
73
screen orientation corrected thanks but colors are distorted
The profile is EXACTLY for what you have on TV. The problem is no longer in profile.
The software you provided is the correct software. There is an lvds socket incompatibility on the motherboard, which varies according to the panel. There is also a smd part sequence difference.
U Çevrimdışı
Uluhan
17 Kas 2021
segili hocalarım 23454347 bu panale göre yazılım için yardımcı olurmusunuz
yokoono Çevrimdışı
73
Inside, on a white label, is the panel code. Must fit with VES236xxxxxxx). I'm interested in the full code.
