screen orientation corrected thanks but colors are distorted
The profile is EXACTLY for what you have on TV. The problem is no longer in profile.
The software you provided is the correct software. There is an lvds socket incompatibility on the motherboard, which varies according to the panel. There is also a smd part sequence difference.
segili hocalarım 23454347 bu panale göre yazılım için yardımcı olurmusunuz
Panel yazılım lazım varsa teşekkürler..
Inside, on a white label, is the panel code. Must fit with VES236xxxxxxx). I'm interested in the full code.
