kaynakci19796734
25 May 2019
6
If I do not get the motherboard wrong (17mb45-3) I DO NOT HAVE A USB CONNECTOR. So you can only update with a programmer.
Google translate:
Görüntülenen resimlerden sonra, TV'de yazılım değil, ekran sorunları var. Sıvılar ekranın altına girdi.
Panel şeritleri hasar görmüşse, başka hiçbir şey yapamazsınız.
TV daha 1 günlük ek değmedi açık olduğunu akşam farkettik.degisim talep edeceğim.servisi aradım bugün yarın gelirler bakmaya
yokoono Çevrimdışı
Have you tried installing a new software and then the defect appeared?
I think you made the wrong update. You will need to try another software.
cata33 Çevrimdışı
cata33
24 Kas 2018
21
[QUOTE = "yokoono, post: 91076, member: 6137"]
Do not find your country or any other country?
[/ QUOTE]
yes...but not going to flashing nothing....the led is flasing fast ,i relase the ok and nothing hapen...just going to thesame thing...see the picture
he just starting to setup tv ,but no meniu no nothing,only rebooting whet i try to pres OK
Video:
yokoono Çevrimdışı
Adem bey yeni aldığım TV nin panel arası açık ne yapmalıyım
Google translate:
Seni rahatsız ediyorsa, ekrandaki leke (ortadan aşağıya) yazılımdan değil, panelden.
[/ QUOTE]
Only a part of the new software has been installed. Enter the service menu with MENU + 4725 and put the picture.
cata33 Çevrimdışı
cata33
24 Kas 2018
21
[QUOTE = "yokoono, post: 91083, member: 6137"]
Google translate:
If it bothers you, the stain on the screen is not from the software, but from the panel.
yokoono Çevrimdışı
[/ QUOTE]
Video:
Then you have to unzip the cover and tell what motherboard and what display you find.
1. Unzip the software and put it on the stick
2. Push the stick into the TV
3. Press the OK key on the remote control and hold it down
4. Put your TV in the socket.
5. Release the OK key when the stb light flashes quickly or after approx. 10-15 sec
6. When the update is complete, the TV can start with the image, it can restart or just stop.
7. Turn off the TV.
8. Remove the stick.
kaynakci19796734
25 May 2019
6
Google translate:
Panel den olduğu belli, üretim hatası mı montaj hatası mı, böyle olması normal mi
cata33 Çevrimdışı
cata33
24 Kas 2018
21
watch the video...no update is make !
i open the cower and this ismy motherboard
[QUOTE = "yokoono, post: 91094, member: 6137"]
Then you find the unzip.
3. Press the OK on the remote control and hold it down.
6. When the update is complete, the TV can be restarted.
7. Turn off the TV.
[/ QUOTE]
I know how to update it.
17mb211s
yokoono Çevrimdışı
7. Turn off the TV.
[/ QUOTE]
17mb211s
I saw what the motherboard is. You also need the panel code. If you want, you can try a software here for your motherboard.
https://tavsiyeforumu.com/konu/vest...b120-mb130-mb140-cekirdek-yazilim-konusu.445/
cata33 Çevrimdışı
cata33
24 Kas 2018
21
[QUOTE = "yokoono, post: 91107, member: 6137"]
Vestel 17MB211S is motherboard. PANEL (DISPLAY) ???. Is VES315 ????????????
[/ QUOTE]
how to find PANEL (DISPLAY) ????????
ok ... i will take some picture!
i will back
who help me i will make a small donation of 10 pound !!
Bahsettiğim yer burası ışık sızması var
[QUOTE = "yokoono, post: 91109, member: 6137"]
Google translate:
The panel was washed with excess liquid flowing through the panel. There are some strips that can rust. The panel is in danger. It cannot be repaired or expensive. Sorry.
[/ QUOTE]
VES315WNDL-2D-N23 LCD PANELS
[/ QUOTE]
yes ves 315
ves315wndl-2d-n23
