If I do not get the motherboard wrong (17mb45-3) I DO NOT HAVE A USB CONNECTOR. So you can only update with a programmer.
Google translate:
Görüntülenen resimlerden sonra, TV'de yazılım değil, ekran sorunları var. Sıvılar ekranın altına girdi.
Panel şeritleri hasar görmüşse, başka hiçbir şey yapamazsınız.
TV daha 1 günlük ek değmedi açık olduğunu akşam farkettik.degisim talep edeceğim.servisi aradım bugün yarın gelirler bakmaya
Have you tried installing a new software and then the defect appeared?
I think you made the wrong update. You will need to try another software.
[QUOTE = "yokoono, post: 91076, member: 6137"]
Do not find your country or any other country?
[/ QUOTE]
yes...but not going to flashing nothing....the led is flasing fast ,i relase the ok and nothing hapen...just going to thesame thing...see the picture
he just starting to setup tv ,but no meniu no nothing,only rebooting whet i try to pres OK
Video:
Adem bey yeni aldığım TV nin panel arası açık ne yapmalıyım
Google translate:
Seni rahatsız ediyorsa, ekrandaki leke (ortadan aşağıya) yazılımdan değil, panelden.
[/ QUOTE]
Only a part of the new software has been installed. Enter the service menu with MENU + 4725 and put the picture.
[QUOTE = "yokoono, post: 91083, member: 6137"]
Google translate:
If it bothers you, the stain on the screen is not from the software, but from the panel.
[/ QUOTE]
Video:
Then you have to unzip the cover and tell what motherboard and what display you find.
1. Unzip the software and put it on the stick
2. Push the stick into the TV
3. Press the OK key on the remote control and hold it down
4. Put your TV in the socket.
5. Release the OK key when the stb light flashes quickly or after approx. 10-15 sec
6. When the update is complete, the TV can start with the image, it can restart or just stop.
7. Turn off the TV.
8. Remove the stick.
Google translate:
Panel den olduğu belli, üretim hatası mı montaj hatası mı, böyle olması normal mi
watch the video...no update is make !
i open the cower and this ismy motherboard
[QUOTE = "yokoono, post: 91094, member: 6137"]
Then you find the unzip.
3. Press the OK on the remote control and hold it down.
6. When the update is complete, the TV can be restarted.
7. Turn off the TV.
[/ QUOTE]
I know how to update it.
17mb211s
7. Turn off the TV.
[/ QUOTE]
17mb211s
I saw what the motherboard is. You also need the panel code. If you want, you can try a software here for your motherboard.
https://tavsiyeforumu.com/konu/vest...b120-mb130-mb140-cekirdek-yazilim-konusu.445/
[QUOTE = "yokoono, post: 91105, member: 6137"]
[/ QUOTE]
vestel 17mb211s
Bahsettiğim yer burası ışık sızması var
Google translate:
Panel, panelden akan fazla sıvı ile yıkandı. Paslanabilecek bazı şeritler var. Panel tehlikeye girdi. Onarılamaz veya pahalı olamaz. Özür dilerim.
[QUOTE = "yokoono, post: 91107, member: 6137"]
Vestel 17MB211S is motherboard. PANEL (DISPLAY) ???. Is VES315 ????????????
[/ QUOTE]
how to find PANEL (DISPLAY) ????????
ok ... i will take some picture!
i will back
who help me i will make a small donation of 10 pound !!
[QUOTE = "yokoono, post: 91109, member: 6137"]
Google translate:
The panel was washed with excess liquid flowing through the panel. There are some strips that can rust. The panel is in danger. It cannot be repaired or expensive. Sorry.
[/ QUOTE]
VES315WNDL-2D-N23 LCD PANELS
[/ QUOTE]
yes ves 315
ves315wndl-2d-n23
