elrefaey
29 Kas 2023
10
49
I need to download th full software for
MB110 Toshiba V.2.35.36.0​
I can't download it
please help
P Çevrimdışı
poolsoft
24 Mar 2020
Yeni ana kartın üst veya alt tarafında beyaz kısımda yazan rakamların hepsini kart üzerinde nasıl yazılmışsa aynı şekilde buraya yazın yada yazı ve rakamlara ait net resim çekebilirseniz resim ekleyin. Bu arada kötü bir haber vereyim etiket resmini eklediğiniz tv V5 Yeni aldığınız kart V5 Olupta siz ona V3 Yazılım yüklediyseniz o ana kartın işi zor.
resimleri ekliyorum.
elrefaey
29 Kas 2023
10
49
elrefaey
29 Kas 2023
10
49
Dear sir
I downloaded software
extracted the files
put on a formatted fat32 flash disk
with tv not plugged inserted the flash to usb
while pressing OK from remote I plugged the TV
But the software is not loaded
The TV start flashing green led while Red led is always ON then backlight is turned on with black screen then Red led is off after a while and the green led is ON
Please tell me what i am missing here
FYI the TV has no Picture just Black screen with Backlight on
yokoono Çevrimdışı
Dear sir
extracted the files
1. Can the TV be turned on and off from the remote control?
2. Keep pressing the OK button until the stby LED flashes quickly.
elrefaey
29 Kas 2023
10
49
Yes it can be turned on and off from remote
if the TV was off before it is unpluged then
when plugging it
the green led flashes for 2 seconds
and backlight turns on then off again
and green led become off and the red led is on
I still pressing OK from remote while the sequence above is running and nothing happens
Also i tried to unplug TV while it is Turned ON then insert the flash and press OK from remote then Plug the TV
The turninig on sequence happens without start loading software
I have RT809H programmer, can i use it to flash the software?
İlginiz için teşekkürler. Ben bu kartın kurtarma yazılımını istiyorum.
Okunmazsa üzerinde yazan : 1903 23617000 283382161740 10125203 7100
Mb130 Kurtarma Yazılımı hiç bir zaman olmadı full yazılım verildi bildirimi kontrol edin yükleme talimatı orada yazıyor uygulayın sonucu yazın.
yokoono Çevrimdışı
when plugging it
SPI:
elrefaey
29 Kas 2023
10
49
I flashed the SPI file named Toshiba 32L5660EV 17MB110 VES315WNDS-2D-N12 MX25L1606.BIN you sent last using the programmer
After copying the complete software files on Flash disk do i have to change the names ?
i have copied the four files there names are
mb110_en.bin
mb110_PM51.bin
mb110_RomBoot.bin
usb_auto_update_G7.txt
and did as the procedures but flashing does not start
