L Çevrimdışı
lacrete72
30 Mar 2023
7
hi, sorry for english i'm french and try to fix a problem with this tv.
Grandin UD55VGB18 with a 17MB130p vestel motherboard.
Thank's for help.
hosbulduk Çevrimdışı
hosbulduk
9 Kas 2018
3,721
Thank's for help.
If there is no hardware problem, your problem will be solved by installing the full software on the TV. However, for people living outside of Turkey, accessing the full software through the forum is a difficult option. I am trying to install any software related to the motherboard group and then try to solve the image errors that arise by trying out the panel software shared in the forum. If you want to try, you can also choose the same path or try to request software through the support in your country by email.
What you need to pay attention to is that Toshiba and JVC television brands only work with their own remotes, so you should not install software specific to these brands, otherwise the current remote will not work.
L Çevrimdışı
lacrete72
30 Mar 2023
7
I don't have it, but maybe we can find an equivalent software. I need the panel code (VES550xxxxx).
the panel caode is VES550QNDS-2D-N13.
I try to download the full software from the forum but i don't have permission. there is no problem to me for the remote i got a universal remote.
thank's for your help.
yokoono Çevrimiçi
I have bin for flash memory (MX25L1605). Hitachi. Same motherboard and same panel.
hosbulduk
9 Kas 2018
3,721
As far as I know, you have an MB130 motherboard. But MB130 comes with three different software versions (v3, v4, v5). You need to install the software version that matches your TV. Otherwise, if you install the wrong software, your TV won't be able to install software via USB. Your TV will then become unusable. Do you know which software version is currently installed on your TV?
O Çevrimdışı
onur46
7 Şub 2019
134
Merhaba gorseldekı cıhaz ıcın full yazılım mevcut mudur cıhazda mb95m anakart mevcut yardımlarınızı rıca eder ıyı calısmalar dılerım
