L Çevrimdışı
LOKMAN
12 Kas 2019
12
Merhaba kolay gelsin.17mb96 kartı kullanan vestel led tv ye 17 mb140 kart taktım ekran ters.Panel yazılımı ile çözebilir miyim?panel kodu : VES400UNVS - 2D - N03 var ise yazılım alabilir miyim?
P Çevrimdışı
Proveker
2 Şub 2022
Merhaba Toshiba 50U5863DAT model tv ye yazılım atmak istiyorum hangi yazılımı atmam gerekiyor yardımlarınız için şimdiden teşekkür ediyorum
yokoono Çevrimdışı
Panel profile for 17MB140 panel VES400UNVS-2D-N03
tvdarek
28 Ocak 2022
11
30
I am looking for TV repair software:
DIGIHOME 43287DFP
motherboard: 17MB110
10106066 23363016
matrix: VES430UNDL-2D-N12
The TV does not turn on, the LED blinks 4 times and goes back to standby printout from the computer:
Kod:
UART_115200
DC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
_U
Relocation Offset is: 0CC00000
[AT][MB][start ub][267]
U-Boot 2011.06 (May 19 2016 - 17:22:40)  MBOT-1106.0.10.1364428
msIR_Initialize
Function = UtopiaOpen, Line = 234, UtopiaOpen[MODULE_MIU] strange failed
having MODULE_BDMA
having MODULE_UTOPIA
Open MIU failFlash is detected (0x0507, 0xC2, 0x20, 0x15)
uboot held at [2E2DDF60~2FA00000],size=017220A0
CPU  : Munich
Board: BD_MST220E_D01A_S
DRAM:  250 MiB
Now running in RAM - U-Boot at: 2ED00000
NAND:  [NC_Init]        SDR NAND is detected
CIS is found @Blk0
FCIE is set to 62MHz
512 MiB
*** Warning - set default for mtdparts, using default environment
Creating 1 MTD partitions on "nand0":
0x000000880000-0x000000C80000 : "mtd=2"
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
Can't find "CTRL" partition
restore UBI scan
Volume "MPOOL" found at volume id 0
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MAC:  0x48: 0x6D: 0xBB: 0xA:0x7E: 0xC7
RC type offset = 0x1E1AA0, type = 0x0
uart spi offset = 0x1E1B46, value = 0x0
UART Disabled
ower Down
yokoono Çevrimdışı
DIGIHOME 43287DFP
10106066 23363016
Kod:
UART_115200
DC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
_U
msIR_Initialize
having MODULE_BDMA
CPU  : Munich
DRAM:  250 MiB
CIS is found @Blk0
512 MiB
restore UBI scan
In:    serial
Out:   serial
Err:   serial
UART Disabled
ower Down
Try. You have firmware for stick and SPI for programmer.
P Çevrimdışı
Proveker
2 Şub 2022
Tv deki sorun nedir?
Ekran logosu geliyor gidiyor yeşil ve kırmızı ışık yanıyor
Ekran toshiba yazısı böyle geliyor ve kapanıyor sonra tekrar geliyor yeşil ve kırmızı ışık yanıyor sorun ne olabilir bilmiyorum forumlarda bi video izledim vestel tv de bu sorun adamın başına gelmiş yazılım güncellemesi yapmış açılmış Televizyonu
Tako222
3 Şub 2022
Vestel logosundan sonra tv açılmıyor.Full yazılım varsa rica ediyorum . Teşekkürler
Yazılım link
yokoono Çevrimdışı
The motherboard cannot be updated with this firmware. Also after changing the SPI, nothing has changed, the same printout at startup.
If the motherboard does not have a hardware problem then the nand / emmc memory must be rewritten. Unfortunately I don't have the necessary software.
