U Çevrimdışı
ucevik
21 Ağu 2019
65UD8950 LD tv'ye sahibim. Youtube girişinde sorun olduğundan servis çağırdık. TV de bulunan v. 3.62.24.0 yazılımını v.3.62.43..0 ile değiştirdiler ve sorun çözüldü. Ancak, samsung telefonumdan daha önce kablosuz oynattığım videolarda daha önce sorun yokken şimdi bu videolar oynarken kesintiler oluyor. Acaba bu sorunu ortadan kaldırabilecek daha yeni yazılım mevcutmudur?
Saygılarımla.
dethroker
29 Eki 2019
17
39
Hello,
Can someone please share with me full firmware (4 files) to flash with "OK" button for my Philips 49PUS6031/12 (17MB120 from Polish market)?
Got symptoms just like in this thread:
Would like to try to repair it myself this way because TV's warranty ended.
cheers
Hello,
cheers
Forgot to attach my product table:
dethroker
29 Eki 2019
17
39
Przepraszamy za spam :-)
W pobliżu
Muszęte pliki: mb120_en.bin RomBoot.bin PM51.bin usb_auto_update_G6F.txt
dethroker
29 Eki 2019
17
39
I'm not at home right now but as far as I can see in the Philips/Vestel specsheet:
LCD panel 23336785 F+L(QNDL2DU11CN_120)49400_WJWORSB_BL_VEL
On the back sticker it also says:
VES16.1E LA
The panel code tag is glued to the board that protects the screen. VES390 ??????
Here is a software for the VES490QNUS-2W-U01 panel (maybe this is the panel)
If you main is 17MB120.
BTW, I downloaded your .rar file but I can not open it with 7zip.
yokoono Çevrimiçi
WINRAR ?
I tested and it is OK. Unzipped with winrar. You also have the latest software from the manufacturer. Put on the stick, press and hold the power key on the TV and put the TV in the socket. Release the key when the update starts.
dethroker
29 Eki 2019
17
39
WINRAR ?
This file is probably corrupted, downloaded it 3 times already and WinRAR also won't open/extract it.
dethroker
29 Eki 2019
17
39
WINRAR
Panel is VES490QNDL-2D-U11
OK, got it with different version of WinRAR. So, the software from your first link (post #6405) will not be good because the panel is different?
Regarding panel I also found this information:
yokoono Çevrimiçi
When I posted the software I didn't know what panel is on the tv. If it is true that it is VES490QNDL-2D-U11 I currently do not have access to the software archive to search. I come back as soon as I can with a result.
At this time the TV is not working? Just the stb led blinks?
dethroker
29 Eki 2019
17
39
Thanks for your help. I'm at work right now and TV is not mine, trying to help my friend. Panel is working, TV turns on, shows Philips logo and then does nothing. Just like in this case:
I want to go to his house after work and try with recovery firmware flashing but I have only the upgrade package from official Philips support site and I suppose it won't work in this flashing mode (only from software menu which is not available at the moment). That's why I asked for the full software, the type you linked in post #6405.
