Merhaba
Vestel/Telefunken bu gün yeni bir yazilim yolladinyüklerken TV kapandi bir dahada acilmiyor. yardim ederseniz sevinirim...
You have a 17MB95M motherboard and a 49-inch panel on the TV. I have nothing for this combination. You can try the software below at your own risk.
full
Left click on 17MB95M full
The files in this link are deleted
Possible reasons:
  • The expiry date of these files is over
  • These files were deleted by the owner
  • The link you opened is incorrect
Restore files
Files can be restored within 30 days after deletion.
These files have been permanently removed and cannot be restored.
linkteki yazılımı yükliyebilirsiniz.
Teşekkürler. Deneyince sonucu yazarım.
Do you know the installation procedure?
1. stick fat32
2. unzipped
3. put the 3 files on the stick
4. stick in tv
5. press and hold the ok key on the remote control
6. TV in socket
7. when the left LED flashes quickly, the ok key is released
8. wait for it to finish (3-5 minutes).
hocaM COK TSKLER ELİNİZE EMEGİNİZE SAGLIK SONUC MUKEMMEL
1. stick fat32
2. unzipped
4. stick in tv
6. TV in socket
Yes i do it all right
TV LED lamp is off. It never burns
Even if I plug it without USB, the LED is no longer lit. :-(
Then the TV may have a hardware problem not a software one. If it is still software, it can only be resurrected by directly rewriting the spi and / or nand memory. Rewriting is done with a programmer.
Telefunken service sent me an upgrade program
While loading it in the same way, the TV did not turn on again.
but thanks for your help.....
