rikols
24 Tem 2019
And panel, display is VES550XXXXXXXX ?.
What does VES550 write?
Where can I find the information which panel it is?
Thats the panel model.
yokoono Çevrimdışı
You have VES550 QNES-2D-U01 and main 17MB120
Unfortunately, I only have to:
1. QNEL-2D-U01
2. QNDL-2D-N11
3. QNDS-2D-U12
4. QNDS-2D-N12
Some softwares are for the stick, others are binaries for the programmer. What do you think will help?
rikols
24 Tem 2019
1. QNEL-2D-U01
2. QNDL-2D-N11
3. QNDS-2D-U12
4. QNDS-2D-N12
OK, I see.
Can you send me all the files that I need?
Go ahead and send me all the files and maybe I can perform a test and see if I can make for example QNEL-2D-U01 work well with my set.
I bought the TV quite cheap since it is defective so it will be no big deal if the software doesn't apply. :)
yokoono Çevrimdışı
RIKOLS.
For this panel (QNEL-2D-U01 ) I have the bins for the 2 flash memories U11 and U13. I'm writing with the programmer. It is ideal that the two memories be replaced with new ones.
rikols
24 Tem 2019
RIKOLS.
For this panel I have the bins for the 2 flash memories U11 and U13. I'm writing with the programmer. It is ideal that the two memories be replaced with new ones.
Thanks alot yokoono!
Which programmer do you use?
And can you also send me the 17mb120 files?
I'm talking about the bin-files firmware.
yokoono Çevrimdışı
You have the 2 bin downloaded in the FILE FM site.
I use the CH341A programmer.
For the stick, if you're lucky, try this. Unzip and put the four files on the stick. I guess you know the update procedure.
rikols
24 Tem 2019
Thank you so much for the help!
I think I got the hang of how the update will be accomplished.
Press and hold OK on the remote, plug the tv in to the wall socket, release OK as the red led starts flashing on the tv. Right?
What if it won't recognize the USB and won't boot? Is that a case where I need to re-program the U11 and U13?
Once again, I'm very grateful for your effort in this.
Best regards
Rikard
yokoono Çevrimdışı
The procedure is correct.
If the update does not start on the stick, the flash memories with the programmer must be rewritten. There may also be problems with NAND memory. If it does not work try another stick of 2G max.
Is the stb light flashing fast? Wait 10-15 minutes.
rikols
24 Tem 2019
OK, I will definately give it a try.
Is it a common fault that the programming doesn't start and the IC's needs to be re-programmed?
The stick I'm going to use is 1GB.
I will inform you later whether I succeeded or not. :)
