korgkaya
28 Ocak 2018
23
Vestel 40UA9300 televizyonuma full yazılım rica edebilir miyim ?
yokoono Çevrimdışı
Hi Yokoono,
Yes, at start-up the Hitcahi-logo appears, then the TV restarts, the Hitachi-logo appears once more, then it shuts off.
I tried to replace the PSU board, but that was not the actual fault.
I measured all the voltages and they seem to be correct.
So now I need to give the re-installation of the firmware a try.
Can you provide me with the correct bin-files for this operation?
The serial number on the TV is 7628947 600224.
Thanks in advance.
Best regards
Rikard
To look for compatible software, I need the motherboard and panel code. If you are lucky we can find for the stick or memories written with the programmer.
yokoono Çevrimdışı
For rikols.
That's not what I asked for. The motherboard is 17mb120 ?. The panel is VES550 ???????????.
You must undo the TV cover to read the panel model.
P Çevrimdışı
proff2000
19 Tem 2019
merhaba 32hb5000 32inç tv açılıp kapanma sorunu var mumkunse yazılım gonderebılırmısınız tesekkur ederım
urun kodu: 10107735
sn:7942639701492
