@yokoono Sorry but how to load it up ? I don`t have programer so been looking for full rom to load via usb drive. I still can perform update by pressing ok and connecting to the socket just stops with black screen
I have nothing useful for the stick.:bilmiyom
Merhaba. Söz konusu problemlerden sonra TV' yi Menu > Kurulum > İlk kurulum seçenekleri ile sıfırdan kurdunuz mu?
yardımın için teşekkürler! I tried that a few weeks ago. It solves the blocking issues a little bit, but with the time they come back. Especially if we open internet apps.
tek lnb olan yerde higlevel sorun yaratıyor binaya taktığımda sıkıntı yapmadı anlamayamadım 1-2 dakikada halk tv lalegül rv trt3 yıldız tr3hd diyanet tv 100 gibi kanallar duruyor diğer kanallarda sıkıntı yaratmıyor. vestel tv binadada tekli uyduda sorun yaratmıyor.
Tuner katında donanımsal arıza var. Lnb' yi besleme akımı yeterli gelmiyor. En uygun seçenek harici bir uydu alıcı ile kullanmaktır. Merkezi sistemde sorun olmamasının sebebi tesisatta akımı güçlendiren donanım bulunmasıdır.
Hi team,
is is possible to get firmware for Toshiba 32W3753DG?
This is the current version:
Issues found:
1. The led flash green and red in the middle of the night. It looks solved disabling the auto firmware update.
2. The TV gets restarted by itself.
3. TV gets stuck. Remote control does not do any action. Image keeps working. Sometimes this finish in a few seconds or the TV restart by itself.
Please let me know which is the best version to update this TV. If possible.
Thank you so much for your help.
Best regards.
@yokoono Master. This problem can solved with software? I think hardware problem.
Hi team,
Issues found:
Best regards.
For this TV model I only have SPI for flash memory. For the stick I have something equivalent with the same motherboard and the same panel. Rewrite at your own risk. I hope you know the installation procedure. If there are problems with the remote control, you can use a Vestel or a programmable one.
Main is 17MB110P ????.
Thank you guys!
merhaba 32r4020h sn:7912571 700202 10111944 ful yazılım bulabilir miyiz
orj kart mb140 varsa mb82 yazlımı da olur kartı değişebilirim
Konunun ilk mesajını OKUYUN! Gerekli bilgileri GÖRSEL olarak paylaşın! TV' deki problemi detaylı olarak yazın!
32r4020h tv nin eprom arızalı değişmem gerekiyor full yazılım ihtiyacım var orjinal kart mb140
Flash chip arızalı ise yüklemeyi nasıl yapacaksınız?
Full yazılım verildi. Sağ üstte çan simgesinden bildirimleri kontrol edin. Yükleme talimatı indirme sayfasındadır. Yükleme sonucunu mutlaka bildirin.
başka mb140 dan eprom yazılımını alıp programlayıcı ile yeni eproma yazıyorum çalıştırıp üstüne usb ile sizin verdiğinizi yazıyorum oluyor deneyip sonucu bildiririm size
Evet o yüzden sormuştum. Bizim verdiğimiz yazılımlar USB bellek uyumlu, programmer ile yüklenmez diye. Sonucu bildirirseniz sevinirim.
işlem başarılı tv açıldı fakat panelde arızalı cıktı ilginize teşekkürler
