- 24 Ağu 2019
- 16,571
Rica ederim.beğene basmam gerekiyormuş ustam. şimdi gördüm teşekkür ederim
Yazdığınız kanallar sayısal kabloda abonelik gerektiriyorsa aboneliğiniz var mı?![]()
L Ludacris34, bu televizyona güncelleme atmam mümkün müdür askeriyede lojmanda oturuyorum burada sayısal kablo üzerinden alıyoruz yayınları bein sports gibi kanalları bulmuyor sadece bein sports1 buluyo o da iyi göstermiyor ama star atv gibi kanalları iyi gösteriyo yani diyeceğim şu ki sanırsam güncelleme atarsam düzelir ama. Bu mümkün müdür bu modelde
Vestel Electronics will not give you the opportunity to make these changes. For repair use the panel profile. How to proceed, translate what is written below.Hello! I changed the board of the TV Vestel TELEFUNKEN T24TX275LPB because on the screen was writen weak or no signal with the same 17mb82S. I flipped the picture but I can't change from JEIDA to VESA or vise versa
. Please let me know if there is a solution
Hi! Please upload the file again because is corrupted.Thanks in advanceVestel Electronics will not give you the opportunity to make these changes. For repair use the panel profile. How to proceed, translate what is written below.
Panel profile:
Ziyaretçiler için gizlenmiş link,görmek için Giriş yap veya üye ol.MB8X ailesi için;
I checked and the archive is ok. Change the unzipping software or use a newer version.Hi! Please upload the file again because is corrupted.Thanks in advance
Please if is possible send file to petardemirev@gmail.com.Thank you in advance
Thanks a lot i have changed the soft and is OK. Will try the TV soft nowI checked and the archive is ok. Change the unzipping software or use a newer version.
If you want to copy the profiles from the TV, a folder called READ is created.Thanks a lot i have changed the soft and is OK. Will try the TV soft now
Hi Yoko !! Can You share how to download the same files from the TV? I know from you for another mainboards to use folder named DownloadmbXX but here is little bit different
Thank You!! Will try!If you want to copy the profiles from the TV, a folder called READ is created.
Благодаря ти!! Ще се опитам!
Hi Yoko !!! Thanks for all !!! I tried your files and those from the old board but no success. I could not change the JEIDA or VESA format. Could be a hardware issue on the new board. Any suggestions?Thank You!! Will try!
Diğer konuda size yazılım verildi.Model: 32HB5000 32inch led tv
SN: 7967412800371
Televizyon açılmıyor.
Mb140 kurtarma Carbon programını kurmaya çalıştığımda 15 dk. beklememe rağmen kurulum tamamlanmıyor.
Yardımcı olabilirmisiniz?
