barutnika
31 Ara 2021
61
Hello
Dear participants, how can I download software PNL.bin file from Vestel TV with mainboard 17mb110p? How should be named the text file in order to download PNL file and what are the procedures to do that using USB Operations? .Thank's in advance
Merhaba
Sevgili katılımcılar, 17mb110p anakartlı Vestel TV'den yazılım PNL.bin dosyasını nasıl indirebilirim? PNL dosyasını indirmek için metin dosyası nasıl adlandırılmalıdır ve bunu USB İşlemlerini kullanarak yapmak için prosedürler nelerdir? .Şimdiden teşekkürler
yokoono Çevrimiçi
Hello
Merhaba
To save the panel profile to the stick, create a folder called downloadpq.mb110 on the stick. If you don't know how to proceed, say so.
barutnika
31 Ara 2021
61
Many thanks to Yokoono for the instructions!!!!:clap2 Is there another way to flip the picture as an example to change the existing software and how it can be done?
yokoono Çevrimiçi
I had problems with the hard drive and lost a lot of data. I know that the PNL or TMG file was opened with a HEX program and a BIT was changed from 0 to 1 or vice versa.
barutnika
31 Ara 2021
61
Hi !! I APPRECIATE an honest answer and if you have an idea how exactly this can be done please share. If not possible please someone else to share how it can be done. I would be grateful if you could attach explanatory notes and photos!! Thank's a lot!!
hakan_special
2 Nis 2019
21
39
merhaba regal mb211 anakartlı televizyonumda v0.69.20.0 yazılım yüklü güncel yazılım var mı bir de bein sports uygulaması var ama bein connect uygulaması yok nasıl yükleyebiliriz
Tv yazılımınız güncel sürümdedir. Tv nin lisanslı internet portalinde ne varsa onu kullanırsınız sonradan uygulama yüklenmez.
stefanoo
22 Ağu 2022
11
stefanoo
22 Ağu 2022
11
Hi, what you write is valid for MB211 motherboard software v3 Software version on this television MB211 Motherboard Software V.0 Titanium Menu
Good point. I wanted to describe exactly how to do it and forgot about versions :) V3 vs V1 difference in sql database is very small (a couple of less important columns were added). What V0 looks like I have no idea :/ I I don't even know how the procedure for save/load settings looks like. However, I assume that people think and when the names of files/tables/columns do not match, they stop the modification process ;) Greetings.
