Bu kart için herhangi bir emmc dökümü ve pin çıkışınız var mı? Teşekkürler!Led sönüp hiç yanmıyorsa flash bellek ile yazılım yüklenemez ana kart değişmesi gerekir.
To save the panel profile to the stick, create a folder called downloadpq.mb110 on the stick. If you don't know how to proceed, say so.Hello
Dear participants, how can I download software PNL.bin file from Vestel TV with mainboard 17mb110p? How should be named the text file in order to download PNL file and what are the procedures to do that using USB Operations? .Thank's in advance
Merhaba
Sevgili katılımcılar, 17mb110p anakartlı Vestel TV'den yazılım PNL.bin dosyasını nasıl indirebilirim? PNL dosyasını indirmek için metin dosyası nasıl adlandırılmalıdır ve bunu USB İşlemlerini kullanarak yapmak için prosedürler nelerdir? .Şimdiden teşekkürler
Many thanks to Yokoono for the instructions!!!!To save the panel profile to the stick, create a folder called downloadpq.mb110 on the stick. If you don't know how to proceed, say so.
Is there another way to flip the picture as an example to change the existing software and how it can be done?
I had problems with the hard drive and lost a lot of data. I know that the PNL or TMG file was opened with a HEX program and a BIT was changed from 0 to 1 or vice versa.Many thanks to Yokoono for the instructions!!!!Is there another way to flip the picture as an example to change the existing software and how it can be done?
Hi !! I APPRECIATE an honest answer and if you have an idea how exactly this can be done please share. If not possible please someone else to share how it can be done. I would be grateful if you could attach explanatory notes and photos!! Thank's a lot!!I had problems with the hard drive and lost a lot of data. I know that the PNL or TMG file was opened with a HEX program and a BIT was changed from 0 to 1 or vice versa.
Tv yazılımınız güncel sürümdedir. Tv nin lisanslı internet portalinde ne varsa onu kullanırsınız sonradan uygulama yüklenmez.merhaba regal mb211 anakartlı televizyonumda v0.69.20.0 yazılım yüklü güncel yazılım var mı bir de bein sports uygulaması var ama bein connect uygulaması yok nasıl yükleyebiliriz
Read this guide. Analogously you can add any application.merhaba regal mb211 anakartlı televizyonumda v0.69.20.0 yazılım yüklü güncel yazılım var mı bir de bein sports uygulaması var ama bein connect uygulaması yok nasıl yükleyebiliriz
Hi, what you write is valid for MB211 motherboard software v3 Software version on this television MB211 Motherboard Software V.0 Titanium MenuRead this guide. Analogously you can add any application.you have the necessary bein connect data.Ziyaretçiler için gizlenmiş link,görmek için Giriş yap veya üye ol.
Good point. I wanted to describe exactly how to do it and forgot about versionsHi, what you write is valid for MB211 motherboard software v3 Software version on this television MB211 Motherboard Software V.0 Titanium Menu
V3 vs V1 difference in sql database is very small (a couple of less important columns were added). What V0 looks like I have no idea :/ I I don't even know how the procedure for save/load settings looks like. However, I assume that people think and when the names of files/tables/columns do not match, they stop the modification process ;) Greetings.
