panterman Çevrimdışı
panterman
31 Ağu 2020
seri noyu nasıl öğrencem, duvara monteli tv
alttaki konuda sorunu belirtip seri no yazın
anghelush20
31 Ağu 2020
Hello guys,
I have a HORIZON tv (which is a MB211S Vestel) for which I want to install the latest software V3.33.10.
What should I install: MB211S_VESTEL_QUI or Picasso core update ?
should I go from current software 3.19.17.2 to 3.19.19, then to 3.26 and then to 3.33.10
or is it ok to update directly with latest version 3.33.10?
Hello guys,
Hi
software download link
Unzip the software.
Copy it into an empty flash drive.
Plug the flash memory into the USB port of the TV.
Turn on the TV.
Press MENU 1 5 0 5 on the remote control.
Software upgrade text will appear on the screen, select YES and press OK.
The software will be installed.
Wait until the software is loaded and turned on again with the TV turned off.
Attention
The software is the first completely di responsibility for Turkey
Dej1980
3 Şub 2018
39
tv açıldıktan sonra logo geliyor sonra siyah ekrana düşüyor. kırmızı ışık yanıp sönüyor. full yazılım mı lazım yoksa güncel yazılımı yüklesem düzelir mi?
