TEKNOwest Çevrimdışı
23 Eyl 2018
10,455
Vestel yazısı gelip beklemeye geçiyor.
Yazılımsal bir sorun mu acaba
1, sayfada mb82 kurtarma yazılımını deneyiniz
L Çevrimdışı
lepro974
24 Ara 2020
Merci beaucoup pour vos informations et votre soutien.
l'appareil fonctionne comme Philips: applaudir: applaudir: cak
verdigin bilgi ve destek icin cok tesekkür ederim.
cihaz Philips olarak calisiyor:clap:clap:cak
Arkadaslar, Desteginiz icin cok tesekkür ederim Philips Tv Olmasi gerektigi gib Calisti :clap
Hello,
I have the same problem on the same Philips TV: 55PUS6031/12 with bar code : 23336004. Could you please tell the procedure to update the TV and the link to the files needed.
Thank very much
L Çevrimdışı
lepro974
24 Ara 2020
And if it's not a secret, what's the problem?
Hi,
When I plug the TV The red led is blinking and the Philips logo appears for few seconds then an gray screen stays for 10 seconds and finaly the TV turn OFF (red led ON). If I press the power button I get the same sequence.
The mother board is a 17MB120
yokoono Çevrimdışı
Hi,
Main 17MB120 and panel VES?????? (QNDL ; QNDS ; QNEL)
L Çevrimdışı
lepro974
24 Ara 2020
I have for VES550QNDS-2D-N11 not VES550QNDS-2D-U11
Thank you for the answer, the first file you gave me 17MB120 VES490QNDL-2D-U11 worked but the screen was upside down.
The second one (VES550QNDS-2D-N11) worked too but instead of having Philips logo I got the Vestel logo and the remote didn't work anymore
yokoono Çevrimdışı
Unfortunately I do not have a panel profile to return the image. If the ok key works on the remote control, it is perfect. If not, use a Vestel remote control. You can also try the software below but I don't know what panel it is for. Or a colleague will help you with the panel software. I do not have anything else.
