muce10
5 Ocak 2024
güncelleme yazılımını bildirim yoluyla gönderdim. Yükleyip bilgi verin.
Hocam yükleme başarılı ama netflix komple yok nasıl yükleyebilirim.
23,230
HI Please let me know or teach me how to download the full software
Hi Yoko I did not try to download the profile yet Do you think they will crash the system?
17MB55 profil ve panel dosyaları :
17MB55 Profile and panel files:
Zipten çıkart, mksquashfs klasörünü içindekilerle FAT32 usb ye kopyala,tvyi beklemeye al ve tak, sonra tvyi aç,olmazsa menü+4+7+2+5 ile usbopreations gel ve OK tuşuna bas.
Unzip, copy the contents of the "mksquashfs" folder to a FAT32 USB, put the TV on standby and connect the USB, then turn on the TV. If it doesn't work, go to menu+4+7+2+5 'USB Operations' and press the OK button.
bulentcan
22 Ocak 2022
9
MB82S yazılımında 135 ve 137 versiyonları var şu anda televizyonumda hangi sürümün yüklü olduğunu nasıl anlayabilirim?
barutnika
31 Ara 2021
60
Thank you very much for your reply. I want to ask is this the way to download the full software? I will try and revert
cihan2206
13 Şub 2018
10
Merhaba Tv duvara sıfır asılı o yüzden menü 4725 ten ekran goruntusu aldim. Tv Netflix ten cikinca kapanmiyor. O yuzden en stabil olan 1.34.25 e donmek istoyorum. Paylasmanizi rica ederim
23,230
This
Hi Yoko .Please can You share how to download the panel software from 17mb55?? Thank You in advance.
dnd this message
HAPPY NEW YEAR Negative .This is my first time dealing with 17mb55.The mainbord is working properly .The panel is broken.I want to change the panel but .... dont know how to download and edit the panel soft
Downloading software from the television is not a file, it is only the panel and profile files of the television. I gave you the files you wanted :) I don't know how to adjust the panel settings.
barutnika
31 Ara 2021
60
This
dnd this message
This
dnd this message
OK Understood Thanks a lot . If I have sucssesfuly edited files i will share here
