Did all 12 televisions come off the same production line? Because you know, even if only the panel selection changes in different production lines, we need to update the software and configuration files we use.The clone file produced by the "master TV" causes the problem to every TV cloned.
If I setup a new "master TV " from the beginning, everything works good with that TV,
Hotel mode, menus disabled, volume set, and always goes to standby after a power cycle. All is good.
But
If I then make a clone from this TV and use it on another (or the same TV) , the problem starts
Please share the label information on the back of the TV visually so that the software can be shared just in case. Share for multiple devices if possible.
