It is enough to just make the one entry in profile composer, the picture I shared above showing the profile composer screen, is all that was needed to make a dev profile file. You do not need swprofile, hwprofile and language profile all of the time.
All you have to remember is the name is correct, so for MB110 it's "mb110_devprofile.bin", when "usb operations" is activated from the 4725 menu on the TV set, the and there are NO FILES called "DownloadProfileMBxxx" on the usb drive, the TV software will look for the following files:
mbxxx_hwprofile.bin
mbxxx_swprofile.bin
mbxxx_langprofile.bin
mbxxx_devprofile.bin
If any of these files are found on the USB, the TV software will read them, and apply the settings in them to the TV configuration, but will NOT change anything that is not mentioned in the file.
So if you have "devprofile" with ONLY "TesttoolSocket" option inside of it, then that is the ONLY dev profile option that will be changed, everything else will remain at current setting.
So NO you don't need to make a full profile just to change one thing, BUT you DO NEED to make sure you put the setting in the correct file. You cannot put "swprofile" settings in "devprofile" for example, if you do the setting will be ignored.
I don't have a button on my post editor to add an exe file only an image or a document, so for those who want the profile composer tool, here it is:
Making a new profile is easy, just open the application:
Then click "New"
and you'll see 3 new nodes appear.
If you expand them by clicking the + symbols:
You will see that there are some defaults for you to start with.
You can add/remove items from the profile by right clicking on them
and you can add new values and data by clicking in the right window
If you get an error about "default.xml" when you click "New"
Simply exit the program, then copy the file "Profile_V0.4.10.xml"
as "default.xml"
Then run the program once more.
Time for me to sleep now.... :-)
Holy fckng shit! Can we create, or add new options to profile files? This is what I'm looking for for a long time if I remember correctly.
Müsait olduğumda biraz kurcalayalım şunu bakalım.
