GX6605s Tuner problemi
rikit
17 Şub 2020
136
Dear send your Receiver dump_all.bin file and the other Software which you want to install.
Upload on the forum or send me through email
ikramdirujii@gmail.com
original firmware:
other firmware:
Hımm,sendeki (oktagon) bilgileri bulduğun yazılıma mı atıyorsun ,birde attıktan sonra tekrar bak dosyaya ,orada ne görünüyor ,yazılımı da uyduya atarken önce mutlaka " flash tümünü sil" yapmayı unutma,ayrıca bazen fabrika ayarlarına döndürmek ,tuneri düzeltiyor ,tabii bende böyle oldu bir kaç kez , ama daha hiç döndürdüğüm tunerden sıkıntı yaşamadım ,bir tanesinde hariç ,o da 6605 yazılımdı (s) olmadan.
usta hepsini denedim sinyal gelmiyor, demekki av2011 tuneri ile rda5815m tuneri uyumlu degil yada yalnizca tek tarafa fixlenebiliyor yani av2011->rda5815m
Ikram dirujii Çevrimdışı
Ikram dirujii
22 Ara 2020
32
30
original firmware:
[URL unfurl = "true"] [/ URL]
other firmware:
Brother R rikit the file you sent me is 8mb.
So do you want to install the 4mb Software in your 8mb flash?
Let me confrm please
rikit
17 Şub 2020
136
dear @ricket check this file.
note: I did not fix the panel, we can do it later, just check the tuner
hello Ikram dirujii Ikram dirujii ,
with this firmware I also get no signal !
I tried with and without a factory reset, but no Chance. (I have set diseqc correctly)
why are there problems with the tuner RDA5815m? Firmware with AV2011 no problem !
Ikram dirujii
22 Ara 2020
32
30
70% Software manufacturer keeping the remote and tuner data all control in xml files.
But 30% manufacturer keeping basic control in Kernel.bin file, like tuner, remote.
For example in istrong new software we can't change the remote from the xml file.
Because the are controlling the remote from the Kernel.bin,
I suggest you try the titan Software with different tuner configuration.
Like RDA5812
RDA5812M
and many more which is showing in NCIT tool.
I'm sure your box not support the exact tuner which is showing.
Your tuner is another not the octagon which is showing.
rikit
17 Şub 2020
136
Like RDA5812
RDA5812M
in widget folder there is a tuner_select.xml and this file is not available with octagon firmware,
i deleted them and tried again again with the same problem
