- 20 Mar 2019
- 3,274
- 74
Try recovery software. I think you know the installation procedure.![]()
I added the mainboard photo, as I see it is 17MB82S
Giriş yap veya üye ol.
For USB I have this:![]()
Good day.
I have a Telefinken l50F185n2v2 TV. There is a problem when turning on, the red indicator blinks and that's it. Is it possible to find a firmware update for this model?
is it possible to download both for USB and for the programmer for Finlux, so that in case of failure with USB you won't be bothered againFor USB I have this:
Finlux 50F6090-T main 17MB95 panel V500HJ1-LE1C1
For programmer (dump) I have this:
Hitachi 50HXC56 main 17MB95S panel V500HJ1-LE1 flash MX25L1605E
Finlux 50FLHYR185L main 17MB95S-1 panel V500HJ1-LE1 Rev C1 flash U10 MX25L1606E
Dude, you are incredible, it worked, thank you a lot. Now I have a problem with the HDMI port, when I plug it into pc and the TV, it does not give any visual and says no signal. Is it related to some software problem, or is it physical? Do you have any guesses?Try recovery software. I think you know the installation procedure.
Good day.
Try at your own risk. I remind you that these motherboards are very easy to brick.is it possible to download both for USB and for the programmer for Finlux, so that in case of failure with USB you won't be bothered again
There is a pretty good chance that your HDMI inputs are burnt out.Dude, you are incredible, it worked, thank you a lot. Now I have a problem with the HDMI port, when I plug it into pc and the TV, it does not give any visual and says no signal. Is it related to some software problem, or is it physical? Do you have any guesses?
yeni taktığın model numarası nedir.?![]()
İyi çalışmalar. Üstteki orjinal kart st by dan çıkmıyor. Alttaki kartı taktım çift gösteriyor. Yazılım rica etsem yardımcı olurmusunuz. Şimdiden teşekkürler.
Televizyon 49”yeni taktığın model numarası nedir.?
ayrıca 2 panel etiketi birbirinden farklı.?
Teşekkür ediyorum yazılımı indirdim ancak daha vaktim olmadı yüklemeye. Yükleyince sonucu yazarım.bildirim çanından full yazılımı indirebilirsin. Yükledikten sonra sonucu yazın.
