65UD8950 LD tv'ye sahibim. Youtube girişinde sorun olduğundan servis çağırdık. TV de bulunan v. 3.62.24.0 yazılımını v.3.62.43..0 ile değiştirdiler ve sorun çözüldü. Ancak, samsung telefonumdan daha önce kablosuz oynattığım videolarda daha önce sorun yokken şimdi bu videolar oynarken kesintiler oluyor. Acaba bu sorunu ortadan kaldırabilecek daha yeni yazılım mevcutmudur?
Saygılarımla.
3.62.49 yazılımı mevcut dennenebilir
yokoono Çevrimiçi
I hope that you find the correct firmware. I can't test this one or renaming official upgrade from Philips because I'm at my home, just visited my friend's house after work to make quick photos earlier. I'm going to visit him again tommorow after work if you'll find the software :-) Thanks again mate!
I have nothing for the VES490QNDL-2D-U11 panel. I have for VES430QNDL-2D-U11. But I have a repair software. Unzipped (1 file), put on the stick, press and hold the OK key on the remote control and insert tv in the socket. The OK key is released when the stb LED flashes quickly and the update is expected to complete. CAREFUL!!. At Philips there is the possibility of a "ci plus key fail" warning.
dethroker
29 Eki 2019
17
39
Thank you for your help. I just got firmware package directly from Philips, so I'll leave it here for other people in need:
I just hope that NAND flash on the motherboard is operational and everything will go smoothly. We'll find out in a few hours :-)
dethroker
29 Eki 2019
17
39
Yeah but this is the full package from Philips directly (4 files inside) and your archive contains only 1 file (upgrade) as far as I could tell. I may be wrong.
yokoono Çevrimiçi
ftp://t-1000.dlinkddns.com/VES16.1E_2.40.2.0_10105894_full.zip
Not accessible.
dethroker
29 Eki 2019
17
39
It works, at least from polish IPs - checked from my workplace pc also on mobile data connection on my phone. File is hosted on my router at home, uploaded it a few moments ago via VPN. Three different ISPs, all is OK for me.
Update:
Uploaded also on files.fm:
yokoono Çevrimiçi
I gave you an older version of VES16.1E_2.40.13 instead of VES16.1E_2.40.2.0.
We are waiting for news if it has been solved with Philips software.
Alpin_83
4 Ocak 2018
6
merhabalar 49ub9650 televizyon sahibiyim SN7694693 600006 aldıgımdan beri guncelleme yapmadım en iyi güncelleme hangisidir anakartı nedir soylermisiniz
GRAND1 Çevrimdışı
GRAND1
9 Haz 2018
8
55
Sn.Fikoloji kolay gelsin..
Temmuz ayı içinde sormuştum..tekraren soracağım kusura bakmazsanız..resimlerini gönderdiğim tv ye yazılım güncellemesi geldi mi..yapmam gerekir mi? Teşekkürler..
Bı yazılım geldi 3.62.43 olarak ama henüz yükleme yapmadım, biraz yoğunum onumzdeki günlerde ekleyeceğim
