SKORP
27 Şub 2021
20
Спасибо! о результате сообщу.
У меня есть бин SPI для флеш-памяти. Это хорошо?.
не помогло пстоянно моргает красный светодиод
maho02
12 Kas 2019
12
49
hi lewel tv çoğunlukla kumandayı algılamıyor kumanda denendi.
P Çevrimdışı
Piotr3m
10 Haz 2021
7
Good morning.
I hope you can help me with my TV. It's Phillips 49PUS6031/12 , polish market.
It had bootloop, I've reflashed it using firmware from
Now it starts ok but displays Vestel logo and remote control is not working (due to changed IR code, I guess). So I guess that reflash with firmware for Philips would fix it completely.
I've noticed that in post #6,431 there was posted firmware for this TV - but it's not available anymore.
Do you happen to have access to that full firmware?
Thank you for any help in advance.
Thank you for your help. I just got firmware package directly from Philips, so I'll leave it here for other people in need:
I just hope that NAND flash on the motherboard is operational and everything will go smoothly. We'll find out in a few hours :-)
dethroker, do you still have this file? Could you repost it?
ferz1984
28 May 2021
Birisi bana yardım edebilir mi? 17MB130P anakart ve VES550QNDL-2D-N12 paneli için BIN FLASH'a ihtiyacım var.
SPI AND NAND PROGRAMMER'ım var.
Good morning.
yokoono yokoono master supports non-Turkish TV software, I tagged him, he will help you when he is online
yokoono Çevrimdışı
Good morning.
The remote control does not work because you have written software for another TV that uses another remote control. Because the OK key cannot be used, you cannot make another update. For repair, you need a programmable remote control or a programmer and to recreate the flash memory with the BIN software specific to the TV.
You have 17MB120 full v2.40.13
