- 20 Mar 2019
- 3,002
- 74
Look.Hi pls send me, I have programmer. I will try.
Giriş yap veya üye ol.
şimdi bu konunun ilk mesajinı okuyun sizden istenilen bilgilerini buraya yükleyin.Pek anlamıyorum kusura bakmayın alıntı vs resim ve modeli yükledim bilgileri olmamış keşke biraz daha sakin ve düzgün iza etseniz msj silmeyi bilmiyorum
Yukarıdaki mesaj size ait. Bu mesajın neresinde TV'ye ait bilgi mevcut?Profilo TV de Profilo uygulaması açılmıyor yardımcı olun yazılım lazım
Güncelleme yazılımı verildi. Sağ üstte çan simgesinden bildirimleri kontrol edin. Yükleme talimatı indirme sayfasındadır.Merhabalar
Vestel smart tv için güncel yazılım alabilir miyim
The motherboard worked with panel VES315UNDA-2D-N11. Why is it on TV now, I don't have the panel profile. You can save the TV panel profile (pq) on the stick and post it here. Maybe a colleague can help you.Hello,
I am looking for USB Firmware for Toshiba 32L3733DG, Mainboard 17mb110p, panel VES315UNDB-2D-N11. Problem is that mainboard was completely dead, i replaced the mainboard but now have bad image because panel settings of the replacement board are different.
I do have programmer for both Emmc and SPI rom. Ive tried putting original SPI rom 25L1606E on replacement board but sadly no luck, same exact results. Is there any tutorial or something on how to save tv panel profile to USB stick?The motherboard worked with panel VES315UNDA-2D-N11. Why is it on TV now, I don't have the panel profile. You can save the TV panel profile (pq) on the stick and post it here. Maybe a colleague can help you.
I don't have software for the stick. If you have a programmer, I can help you with rewriting the SPI memory.
1. Format a stick with FAT32I do have programmer for both Emmc and SPI rom. Ive tried putting original SPI rom 25L1606E on replacement board but sadly no luck, same exact results. Is there any tutorial or something on how to save tv panel profile to USB stick?
selam ustam elmde bu model vestel tv var youtueye girmiyor netflix yok yazılımla halledebilirmiyz. saygılar
Menu > 4725 yaparak ekran görüntüsünü eksiksiz paylaşın.![]()
Öncelikle aşağıdaki bölümü detaylı şekilde okuyun ve mesajlarınızı doğru konu altına yazın;Merhaba kolay gelsin. Mevcut yazılımda ara sıra donma sorunu oluyor. Daha güncel netflix li yazılım var mıdır?
Ayrıca her ihtimale karşılık FULL yazılımda gönderebilir misiniz?
Teşekkürler.
55UB9100s
MB120
7800957-700064
uygulama yükleyemiyorum.
flashed the SPI rom (out of circuit), still exactly the same behaviour - toshiba logo with rainbow all over the panel. Dunno, maybe there is some kind of key combination or something to force reload info from SPI rom or something.. For panel profile - wasnt sure if i should export it before flashing SPI rom or after, so did it bot before and after, uploading both results. I have no idea which file is the panel profile, so just loading whole content of the flash drive..1. Format a stick with FAT32
2. Create a folder called downloadpq.mb110
3. Type MENU and 4725
4. Go to USB Operations and type OK
After 5 seconds the panel profile is saved.
SPI:
Ziyaretçiler için gizlenmiş link,görmek için Giriş yap veya üye ol.The memory is not rewritten in the circuit.
