carmelo
16 May 2023
yokoono Çevrimdışı
Main board is Vestel 17MB110P
First sound only with no picture(backlight still on) . Than tried firmware update which I downloaded from a guy on youtube and now only standby light flikering and nothing comes on.
Full software. If the remote control no longer works, use a programmable one.
carmelo
16 May 2023
Good morning I just tried the Full software which you told me but still the same. Maybe there is something else which I am missing. I am just amature electronics hobbyiest, but just the same thank you for your help and wish you a good day.
camelot41
17 Tem 2020
116
29
yokoono Çevrimdışı
If you wrote the wrong software, there is a possibility that the software in the NAND memory and/or the software in the flash memory may be corrupted. In both cases, apart from the specific software, you need a programmer for rewriting. Call a service.
L Çevrimdışı
luckyesref
17 May 2023
Televizyon orijinal. Ana kart değişikliği yapılmadı. Panel değişikliği yapılmadı.
Varsa tüm güncellemeleri sıfırdan yapmak istiyorum. Yardımlarınız için şimdiden teşekkür ederim.
