I asked you not to delete the logo if it does not bother you. This is done in several stages. You have rewritten the software WITH THE OTHER.
Repair the software and follow the first step.
First step - PROFILE SALVATION
1. Start TV
2. Insert a fat32 stick at the usb. (On stick, in Windows, created a empty folder called downloadprofile.mb120)
3. Enter the service menu with MENU + 4725
4. Go to USB Operations
5. Click OK on the remote control
6. Back / Return
7. Power off to stop the TV
The STB light starts blinking fast. Now SAVE PROFILE ON STICK. When stopped, remove the stick.
You have a stick with the tv profile. SAVINGS IN THE LAPTOP ARCHIVE. Maybe you need him.
Second step later.
I can't even start the tv and the files that you gave me yesterday doesn't help like it did yesterday. How to repair?
Thanks for the help
I told you that the logo can be removed BUT I HAVE NOT SAID AND HOW. I was sure you would hurt your TV. You used a profile that is not for your TV.
See now if it helps. It has a single pkg file.
Sorry just followed the other users instructions. I will try later today! Thanks again!
arkadaslar merhaba ben bugun cekirdek versiyon yukliyeyim yukselteyim dedim fakat tv kapandi acildi ekranda vestel yaziyor sadece sanirim farkli bir versiyon yukledim cihazimin modeli fotografta yaziyor lutfen bu modele uygun full versiyon bilgisi olan varsa paylassin tesekkur ederim simdiden
Yes, but you downloaded and copied in TV a profile that is not from the tv you have or modify something wrong in profile.
mb81 uyarsa d eniyorum
Teşekkürler..
[QUOTE = "yokoono, post: 86799, miembro: 6137"]
1. Descargar aquí
2. Descomprima y suelte los archivos.
3. También ponga el upgrade_mb120.bin descargado anteriormente. TOTAL 11 ARCHIVOS.
4. Repita el procedimiento con la tecla OK en el control remoto.
5. Si no funciona, presione el botón de encendido / apagado de la TV
[/ QUOTE]
¿Esto se aplica a Philips?
1. Descargar aquí
[/ QUOTE]
Did you fix your TV? You have a software for Finlux that has the same motherboard and the same panel as your tv (17MB120 / VES430QNDL-2D-U11). If you follow the installation procedure it will have to be ok. If not, the memories with the programmer will have to be rewritten.
You have an older version here. Maybe it fits your panel
I guess you know the installation procedure (unzip, usb fat32 stick, ok key pressed for 10 seconds, tv in the socket)
xxxxxxx
mb120_en.bin
mb120_PM51.bin
RomBoot.bin
usb_auto_update_G6F
That's how the stick looks.
Unzip, usb fat32 stick, ok key pressed for 10 seconds, tv in the socket
Thank you a thousand times! It worked!!! A true hero! :):)
Hadi geçmiş olsun :) ,bir daha tvde sorun yoksa ,yazılımla falan oynamazsın, sevgili kevjay :ok
No!:)
Everything works now but the menu is different (which I like) plus that it says Vestel instead of Andersson on the logos :P
If the Vertel logo bothers you can remove it with Vestel Toolbox.
Thanks! Not really bothering me just different. Where do I get vestel toolbox?
Downloading from Google. But it is a procedure to be followed. But if there are no problems .....
Can't find it when I did a search. Could you provide a link! Thanks :)
For kevjay Vestel Toolbox
Thank you so much! How do I use it?
Bunu indir:
Oku.txt dosyasın okuyarak uygula.
aldığın sw profilini önce "yedekle"
sonra toolbox ile sw profilini aç
Config --> (+) BootLogo ---> Enabled -TRUE- yazan yere çift tıklayıp -FALSE- yap ve kaydet
Profile isimli boş klasör yarat
modladığın sw profil dosyasını Profile klasörüne kopyala
usb belleği tvye tak, menü+4+7+2+5 ile usboperations gelip OK tuşuna bas
tvyi kapatıp-aç ,logo yok olmuş olur :ok
Ok! So this was probably not a good idea! The tv is now blinking again like yesterday and not starting :( Blinking red on the standby-button.
@kevjay ;
Farklı profil olamaz,zaten verilen profil yok.
"profiller.zip" tvden profil almana yarayan dosyalardır,neyi nasıl yaptığını bilemem, sadece tvden aldığın sw profilde logoyu kaldırıp,tekrar tvye geri yükleyecektin :)
Alttaki yokoono dosyasını indir tekrar yükle,vestel logo olan, ve tv ile fazla oynama :ok
@yokoono ;
Tvde bulunmayan profil nasıl oluyor :)
(How can a profile not be found on TV?)
EK 1:
EK 2:
Bu konu hakkında konuşmayı bıraktım artık :)
Tekrar Merhaba.
Maalesef Gönderdiginiz yazilimi yükleyemedim cihaz kabul etmedi.
Ariza: Cihazin anakarti arizaliydi degistirdim su an calisiyor ama Resimleri ters gösteriyor.
size tekrar taktigim anakart, Panel ve Model etiketini Gönderiyorum. ilgilenirseniz cok sevinirim.
If you have not yet solved the TV you have a Finlux software that has main 17MB120 and panel VES550QNDS-2D-U12
eline sağlık cok gözel omuş
Selamlar;
Kullandığınız belleğin veri aktarım hızını kontrol ediniz.
Dosya ayıklama esnasında (Extract) sorun olup olmadığı önemli
Kolay kolay sorun yaşanmaz yükleme sırasında, sorun devam ediyorsa bilgi veriniz önce full atıp üzerine upgrade etmeyi deneriz. ?
tesekkurler deneyip bilgi vericem umarim olur
[QUOTE = "yokoono, inlägg: 86962, medlem: 6137"]
Ja, men du lyssnar inte på tv: n.
[/ QUOTE]
Without getting angry at me again the tv still isn't starting. I tried to use the file that you provided yesterday to fix it but it doesn't start. The standby just blinks very fast. Gave up after an hour.
Have a nice evening
