53
Hi Ado,
No, the standby led is not flashing while is on. Only flashes before powering on.
I attach photo where is stuck.
If I press OK or UP/DOWN the TV reboots automaticaly. If I do nothing, the TV remains in this screen "forever".
The serial number is: 7702289 600181
Model: LEU49V300S
Branded as Haier
Thanks for helping me Ado!!!
Does the service menu screen open when we encode from the MENU 4725 remote control?
53
No.
It's fixed on that screen, if I press any button nothing happens, except if I press OK/UP/DOW, then TV reboots.
Then let's do it and try it.
Place the software file in the rar file that I send to you below in a blank flash memory. Please get a fast memory formatted with FAT32 memory. Then insert this memory into the TV and pull out the TV ticket. Insert the TV plug by holding down the OK button on the remote control. As soon as the STBY LED flashes fast, please press the OK button.
Please turn on the TV in 2 minutes, please check again.
I only need a few hours for this
Klingon
28 Şub 2018
13
Ok, once you put the RAR link for downloading I'll try it.
Thanks for your help an effort Ado!!!
Klingon
28 Şub 2018
13
I've tried:
Copy upgrade_mb120.bin on the root of a FAT32 PEN.
and
"Then insert this memory into the TV and pull out the TV power. Insert the TV plug by holding down the OK button on the remote control. As soon as the STBY LED flashes fast, please press the OK button.
Please turn on the TV in 2 minutes, please check again."
And no changes, still not working.
emregenchp
27 Haz 2018
Değerli Arkadaşlarım;
Öncelikle, yazılım yükleme risklerinden bahsetmeye artık gerek dahi olmadığını bilsek de, özellikle zaten çalışan tv lerinde ''Acaba ne olacak?'' düşüncesi ile yazılım yüklemenin tam bir macera olduğunu hatırlatmakla başlamak isterim.
Özellikle MB9X serisi kullanıcılar ve hele ki FAZ2 kullanıcıları için bu konu tam bir maceradır bu nedenle lütfen bir sorun yaşamıyorsanız, ''ACABA'' gibi gerekçelerle yazılım yüklemeyiniz. Sistem çökmesi, servis hizmeti, anakart değişimi yüksek servis maliyeti gibi durumları peşine hatırlatmak ve bu konuda uyarmak isterim.
Bu konu başlığında yalnızca orijinal çekirdek yazılımların paylaşımı yapılıyor.
Yazının sonunda önemli uyarı bölümünü mutlaka okuyunuz.
Yükseltilen yazılımlarda nelerin değiştiğine dair bilgilendirme yapmıyorum bunlar kullanıcı deneyimi olarak arkadaşlarımız tarafından forumda dile getiriliyor.
Yazilima kendisi mudahale eden tuketicilerin urunlerinde garanti kosullarina istinaden sorun yasanabilecegi riskini unutmayiniz.
Cekirdek yazilim yuklerken X bir nedenle tv cokerse full yazilima ihtiyac duyacaginizi aklinizdan cikartmayiniz.
Full yazilimlar boyut anlaminda buyuk olmalari ve her tv icin ozel olmalari nedeniyle isteyen her arkadasimiza full yazilim yollama imkanimin zamansal anlamda olmadigini defalarca yazdim lutfen bunu goz ardi etmeyiniz.
Yetkili servisler kendisi ariza yapan tum urunlere ucretsiz hizmeti zaten sagliyorlar ancak degistirilmis yazilimlari tespit edecek donanima sahip olduklarini unutmayiniz.
Tüm bu uyarilarin hepsi, sizin hem guvenliginiz hem hakkinizi korumak aynı zamanda urununuzun gereksiz ariza yapmasına engel olmak icindir.
Vestel TV Arızaları için MB82 kurtarma yazılımı kullanılabilir. Çekirdek yazılımlar ÇÖKMÜŞ tv durumlarında etken değildir lakin yazılım kaynaklı bug durumlarında ve ürün performans iyileştirmelerinde etkendir.
Tüm bu bilgilerin sonrasında yazılımın nasıl yüklendiğini de anlatalım.
Yazılım yükleme işlemi öncesi ve sonrasında MENU 4725 ile servis menüye girerek versiyon kontrolü yapmayı unutmayınız.
Bu konudaki tüm yazılımlar USB den yüklenebilir yazılımlardır. Bu anlamda kullanılacak olan USB nin veri hızı yüksek bir bellek olması önemlidir zira bazı durumlarda ''Resim Video gösteriyor ama yazılımı yükleyemiyorum'' geri dönüşleri ile karşılaşabiliyoruz. Sandisk belleklerde pek negatif geri dönüş olmamıştır bilgilendirmek isterim.
Yazılım yüklemenin 2 yöntemi vardır (Debug kartları ile yüklenen pro yöntemlerin haricinde)
A- FULL yazılım yükleme yöntemi
Bu Yöntemdeki sıralama şu şekildedir
1- FAT 32 olarak formatlanmış boş bellek içerisine uygun yazılım KLASÖRSÜZ olarak yerleştirilir
2- TV fişi çekilir
3- Bellek TV ye takılır
4- Uzaktan kumandanın OK butonuna basılı tutularak TV fişi takılır
5- STBY ışığı hızlı hızlı yanıp sönmeye başladığında OK butonu bırakılır.
iki dakika içerisinde TV açılacaktır.
B- ÇEKİRDEK yazılım yükleme yöntemi:
1- FAT32 olarak formatlanmış boş bellek içerisine uygun yazılım yerleştirilir
2- USB tv ye takılır
3- MENU 1505 kodlanır ve ''Yüklemek istiyormusunuz'' sorusuna EVET cevabı verilir
iki dakika içerisinde TV işlemleri tamamlayarak kendisi açılacaktır.
FULL yazılımlar sadece FULL töntemi ile yüklenir lakin ÇEKİRDEK yazılımlar her iki yöntemle de yüklenebilir bir zararı yoktur[sm=ok.gif]
Aşağıdaki yazılımlar mümkün olan en güncel resmi yazılımlardır. Daha Detaylı Yükleme talimatları için VESTEL bilgi ve kontrolündeki sitesini ziyaret edebilirsiniz.[sm=ok.gif]
  • 17MB82 1.35
[Gizli içerik]
  • 17MB82 1.37
[Gizli içerik]
  • 17MB82 KURTARMA
[Gizli içerik]
  • 17MB90_MB91R1R2_MB92R3_MB95_MB95S_MB95M_FAZ3_V366y
[Gizli içerik]
  • 17MB91 3.3.8.c Stabil sürüm
[Gizli içerik]
  • 17MB96 - MB91R3 - MB92R4 3.7.6.L
[Gizli içerik]
  • 17MB91R3_MB92R4_MB96_FAZ3_V376n
[Gizli içerik]
  • 17MB96_3.7.6.s Çekirdek
[Gizli içerik]
  • 17MB97_98_0.45.23.32
[Gizli içerik]
  • 17MB97-98 0.45.23.39 Çekirdek yazılım
[Gizli içerik]
  • 17MB100-34.23
[Gizli içerik]
  • 17MB100_34.25
[Gizli içerik]
  • 17MB100 2.7.0.0. Çekirdek Yazılım
[Gizli içerik]
  • 17MB100 2.15.14 (Olumsuz geri dönüşler nedeniyle link kaldırılmıştır)
  • 17MB110 2.22.0.0
[Gizli içerik]
  • 17MB110 2.32.0.0
[Gizli içerik]
  • 17MB110_2.24.1.0_FBTV
[Gizli içerik]
  • 17MB110 2.35.15.0
[Gizli içerik]
17MB110 2.35.40 Çekirdek yazılım
[Gizli içerik]
  • 17MB110S 3.16.6.0 Çekirdek yazılım
[Gizli içerik]
17MB110S 3.16.12.0 Sürüm Çekirdek Yazılım
[Gizli içerik]
  • 17MB120-2.29.6.0
[Gizli içerik]
  • 17MB120-2.29.11
[Gizli içerik]
[Gizli içerik]
  • 17MB120-2.40.2.0
[Gizli içerik]
  • 17MB120-2.40.6.0
[Gizli içerik]
[Gizli içerik]
  • 17MB120 2.45.70 çekirdek yazılım
[Gizli içerik]
  • 17MB120 2.45.101 Çekirdek yazılım
[Gizli içerik]
17MB120 2.45.12.1 NETFLİX Çekirdek Yazılım
[Gizli içerik]
17MB120 2.45.12.2 GÜNCEL ÇEKİRDEK YAZILIM (23.05.2018)
[Gizli içerik]
  • 17MB130 3.1.9.2.0 Çekirdek Yazılım (NONCONNECTED)
[Gizli içerik]
  • 17MB130 3.1.9.8.0 Çekirdek Yazılım (NONCONNECTED)
[Gizli içerik]
  • MB130-3.3.7.3.0 Çekirdek Yazılım (CONNECTED)
[Gizli içerik]
  • 17MB130 3.4.4.6.0 Çekirdek Yazılım (CONNECTED)
[Gizli içerik]
  • 17MB130 3.4.7.1.1.0 Çekirdek Yazılım (CONNECTED)
[Gizli içerik]
  • 17MB130 CONNECTED 3.62.4.0 sürüm çekirdek yazılım. Yotube, Netflix Çözüm içerir
[Gizli içerik]
17MB130 3.62.7.0. Çekirdek Yazılım
[Gizli içerik]
17MB130 3.62.13.0 Çekirdek yazılım [Gizli içerik]
  • 17MB140 CARBON Menü Çekirdek Yazılım
[Gizli içerik]
  • 17MB140 TİTANİUM Menü çekirdek Yazılım
[Gizli içerik]
17MB140 1.38.100 Çekirdek Yazılım
[Gizli içerik]
  • 17MB211 0.49.10 Çekirdek yazılım
17MB211 0.56.1.0 Çekirdek yazılım
[Gizli içerik]
ÖNEMLİ UYARI;
TV yazılımları X bir nedenle çökebilir, Çöken sistemin sorumluluğu, yükleyiciye aittir. Forumda bu bilgiler tamamen DESTEK ve YARDIM amacı ile paylaşılmıştır bu nedenle olası yaşanan sorunlardan bizleri sorumlu tutmamanız gerektiğini hatırlatmak isterim.
Olası sorunlara dair forum içerisinde yüksek kalite oranında bilgi paylaşımı mevcuttur bu nedenle okuduğunuz 2 satır yazı ile yazılım yüklemeye kalkışmak yerine önce bu bilgilerden biraz faydalanmanız tavsiye edilir.
Özellikle 2.2.4.t kullanıcılarına dair yükleme prosedüründeki bazı hassas konuların gözden kaçırılmaması adına aşağıdaki linkten de faydalanabilirsiniz.
Full yazılımlar ile Çekirdek yazılımlar birbirinden farklıdır ve bununla ilgili forum içerisinde defalarca bilgi paylaşılmıştır.
Benim dışımda paylaşılan yazılıların orijinalitesini lütfen sorgulayınız zira modlanmış yazılımlar normal kullanıcılar tarafından yeni sürümmüş gibi sahaya verilmektedir. Orijinal olmayan yazılım kaynaklı olası sorunları ve çökme-performans kaybı risklerini, bunun sonrasında full yazılıma ihtiyaç duyulacağı ve hatta konunun anakart değişimine kadar gideceği, ürünün garanti dışı kalacağını önemle hatırlatmak isterim.
inşallah işe yarayacak
mmuhendis35
27 Haz 2018
merhaba. elimde vestelin yan sanayisi gogen marka tv var. 2.2.4t yüklü sistem vardı. usbden kanal yüklemiyor diye yazılım yükleyeyim dedim. mb95 i yükledim fakat görüntü şuan ters. bir türlü çözemedim. şuan hem görüntü ters hem de usbden kanal listesi yüklerken yine indirme başarısız hatası alıyorum. ne yapmalıyım yardımcı olur musun
