YAPMANIZ GEREKENLER![]()
mb130P için core ve yazılım ihtiyacım bulunmaktadır.
Gönderilmesini rica ederim.
Master![]()
Hi, I need a new software because my TV doesn't turn off. It will restart first, if I press the power off button again, it will turn off. Thanks in advance
I have full software for 17MB230 panel VES550QNDL-2D-N42J. Do you want to try ?![]()
Yes, i would try it.I have full software for 17MB230 panel VES550QNDL-2D-N42J. Do you want to try?
Try at your own risk. If the remote control no longer works, you can use a programmable one.Yes, i would try it.
m. tv açılışta logo da ka
açılmıyorki girebilsek paylaşırız17mb140 finlux tv 32fx420h televizyon için full yazılım istiyorum. tv açılışta logo da kalıyor
Tv sürekli arada kapanıp yeniden açılıyor. Yazılım güncellemesi ile düzelmedi.Yazılımı yükledik. 1-2 hafta test ettikten sonra güncel durumu yazarım.
Thank you. Is it possible to restore the original software if there is a problem with this ?Try at your own risk. If the remote control no longer works, you can use a programmable one.
Do you have the original software?Thank you. Is it possible to restore the original software if there is a problem with this ?
I don't have it :( Do you have it ?Do you have the original software?
