Önemli Vestel - Hi-Level - Nexon - Seg - Telefunken Tv. Yazılım Modlama [ilk Mesaj Güncel]
23,484
Hımm,tamam indirdim,2.5 mb olması normal,çünkü samsungun oscam yazılımı yaklaşık 92 mb tutuyor,
Aşağıdaki kod içinde bugün tvden aldığım veriler var,oscamın çalıştığını görmesekte ,aslında birşeyler yapıyor görünüyor.
Kod:
Unix starttime: 1546103658
Starttime:      29.12.2018 19:14:18
Version:        oscam-build-audi06_19-svn1.20-r11431   <------- BUNU BEN DERLEMEDİM,EN SON 19:14 TV YE ATMIŞTIM "ACABA" DİYEREK,İLK ATTIĞIM
OSCAM İDİ.
Compiler:       mipsel-unknown-linux-gnu
Box type:       generic (generic)
PID:            6828
TempDir:        /tmp/.oscam
GBox tmp_dir:   not defined using: /tmp/.oscam
ConfigDir:      /var/tuxbox/config/
WebifPort:      8888
Web interface support:                   yes
LiveLog support:                         yes
jQuery support intern:                   yes
Touch interface support:                 yes
SSL support:                             no
DVB API support:                         yes
DVB API with AZBOX support:              no
DVB API with MCA support:                no
DVB API with COOLAPI support:            no
DVB API with COOLAPI2 support:           no
DVB API with STAPI support:              no
DVB API with STAPI5 support:             no
DVB API with NEUTRINO support:           no
DVB API read-sdt charsets:               yes
Irdeto guessing:                         yes
Anti-cascading support:                  yes
Debug mode:                              yes
Monitor:                                 yes
Loadbalancing support:                   yes
Cache exchange support:                  yes
CW Cycle Check support:                  yes
LCD support:                             no
LED support:                             no
Emulator support:                        yes
Clockfix with realtime clock:            yes
IPv6 support:                            no
camd 3.3x:                               no
camd 3.5 UDP:                            yes
camd 3.5 TCP:                            yes
newcamd:                                 yes
CCcam:                                   yes
CCcam share:                             yes
gbox:                                    yes
radegast:                                yes
scam:                                    yes
serial:                                  yes
constant CW:                             yes
Pandora:                                 yes
ghttp:                                   yes
Reader support:                          yes
Nagra:                                   yes
Nagra_Merlin:                            no - no EMM support!
Irdeto:                                  yes
Conax:                                   yes
Cryptoworks:                             yes
Seca:                                    yes
Viaccess:                                yes
NDS Videoguard:                          yes
DRE Crypt:                               yes
TONGFANG:                                yes
Bulcrypt:                                yes
Griffin:                                 yes
DGCrypt:                                 yes
cardreader_phoenix:                      yes
cardreader_drecas:                       yes
cardreader_internal_azbox:               no
cardreader_internal_coolapi:             no
cardreader_internal_coolapi2:            no
cardreader_internal_sci:                 yes
cardreader_sc8in1:                       yes
cardreader_mp35:                         yes
cardreader_smargo:                       yes
cardreader_pcsc:                         no
cardreader_smartreader:                  no
cardreader_db2com:                       yes
cardreader_stapi:                        no
cardreader_stapi5:                       no
cardreader_stinger:                      yes
23,484
Şunu da belirteyim,senin bana yolladığın ilk oscam.conf dosyasından sonra bir daha ne yaptıysam o verileri alamadım,oscam.log boş çıkıyor,bugün değişik varyasyonlarla 8 tane mips oscam derledim,bu da "ben tvye 8 kez yazılım yükledim" oluyor,çünkü her seferinde tv açılmıyor.
Sorunun cevabı : hayır hatta azeri cbc sporda bisleri sildim denedim hep,herhalde o kanalı açardı değilmi?
EK:
Ama oscam dosyası yukarıdaki gibi tvde,bana çalışıyormuş gibi geldi.
digiulama Çevrimdışı
digiulama
5 Nis 2018
882
aynen softcam emu ile açması lazım config içine atılıyor sofcam birde her softcam oscam içinde çalışmaz hex hatası verir
burdakileri ikisinide config dosyasına at diğerlerini sil bunlarla açar dreambox mantıgı ile çalışıyor
23,484
Bunlardan da indirmiştim bir sürü bugün :) ama oscam.log dosyası boş çıkıyor,tmp içindeki dosya yani,senin verdiğin programla oscam.server çıkarttım,eskisini sildim,yeni çıkartılanı onun yerine kopyaladım ama yine "oscam.conf" warning :reader hatası verdi,googlede arattım bir sonuç bulamadım bu hatayla alakalı
23,484
Hata tam olarak bu:
Kod:
WARNING: oscam.conf line 41 unknown section [reader].
Hatanın sebebi de bu satır (41.ci satır yani)
Kod:
[reader]
label                         =boss-cccam.dns.army
Bu kodlar da biraz önce tvden alındı,usb üzerinde çalışıyor oscam,9.cu derlediğim oscam :)
Kod:
Unix starttime: 1546125032
Starttime:      30.12.2018 01:10:32       <--- SAAT  ASLINDA 02:10 OLMALI,TV SAATİ BÖYLE 01 YANİ
Version:        oscam-1.20_svn-r11442   <------- BENİM DERLEDİĞİM MİPS OSCAM
Compiler:       mipsel-unknown-linux-gnu-libusb
PID:            599
ConfigDir:      /mnt/hd*/tuxbox/config/
WebifPort:      8888
SSL support:                             no
DVB API with NEUTRINO support:           yes
Debug mode:                              yes
Monitor:                                 yes
LCD support:                             no
LED support:                             no
IPv6 support:                            no
camd 3.3x:                               yes
camd 3.5 UDP:                            yes
camd 3.5 TCP:                            yes
newcamd:                                 yes
CCcam:                                   yes
CCcam share:                             yes
gbox:                                    yes
radegast:                                yes
scam:                                    yes
serial:                                  yes
constant CW:                             yes
dad6403
1 Ocak 2018
34
1- BURADA anlattım sevgili dad6403 :)
2- Bir başka model MB96 kartta olmadığını okumuştum bir yerde,acele etmezsen yakınlarda bir arkadaşın tvde kendim deneyeceğim,burada yazarım .
3- Menü -->Ekran --> Gürültü azaltma buradaki ayarlarla oyna bakalım...(bendeki ayar "kapalı" ve sıkıntı yok)
4- Hayır edilemez,(en azından bende edilmiyor)
Çok teşekkür ederim tüm sorularıma detaylı yanıt verdiğiniz için.
1-Buna çözüm olarak ado hocamızın da sw ve hw profile dosyaları mevcut ama onları yüklersem yine yazılım uçar mı diye çekiniyordum.Sizin konunuzu uyguladım ve kumanda ile hoparlörü kontrol edebiliyorum.Ama ekolayzır ayarlarını hoparlöre uygulamıyor.Olsun böyle de iyi.
2-Acelem yok sizi bu konu hakkında takip edeceğim.Bu gerçekleşirse belki biraz daha ses düzelir.
3-Gürültü azaltma bende yüksekte idi.Şimdi fark ettim ki kapalı değil de düşük yapınca daha iyi oldu.Yani bu sorun da çözüldü bana göre.
4-Netflix olsa iyiydi ama çok önemli değil.
23,484
çalışmayan satırları silip çalışan satırları atabilirsin
İşte böyle kısacık,şifreli gibi yazdığında hiç anlamıyorum ne demek istediğini :smile:
Benim anlayabileceğim şekilde yaz bakayım tekrar :sneaky:
Bu gün derlediğim ve USB üzerinden tvye müdahale etmeden çalışan oscam log dosyaları :smile:
Bu oscam.log sadece 2 satır var,ilk satıra dikkatini çekerim : reason close diyor ;
Kod:
>> OSCam <<  cardserver log switched at Sun Dec 30 17:01:58 2018
2018/12/30 17:01:58 5A71E8F7 p   (reader) b3.vipmgcamd.com [cccam] disconnected: reason close
2018/12/30 17:01:58 00000000   >> OSCam <<  cardserver log switched, version 1.20_svn, build r11444 (mipsel-unknown-linux-gnu-libusb)
Bu da aynı dakikalardaki oscam.log-prev dosyası : Burada da aşağıdaki zaman diliminden sonrasına dikkatini çekerim ;
2018/12/30 17:01:45 22E9E634 p (reader) handa.zapto.org [cccam] connect failed: Connection refused 2018/12/30 17:01:45 2EDD72F7 p (cccam) cccam(r) lx76jo2x.xserver.su: login failed, usr/pwd invalid
Kod:
>> OSCam <<  cardserver log switched at Sun Dec 30 17:01:37 2018
2018/12/30 17:01:37 621B6683 p   (reader) mrsharing.net: resolved ip=148.251.65.197
2018/12/30 17:01:37 621B6683 p   (reader) mrsharing.net [cccam] connecting to mrsharing.net:43
2018/12/30 17:01:37 6D32A593 p   (reader) uyduserver.micel.me: resolved ip=164.132.180.180
2018/12/30 17:01:37 6D32A593 p   (reader) uyduserver.micel.me [cccam] connecting to uyduserver.micel.me:12002
2018/12/30 17:01:37 68BAAD43 p   (reader) x1.fcnoip.org: resolved ip=144.76.192.98
2018/12/30 17:01:37 68BAAD43 p   (reader) x1.fcnoip.org [cccam] connecting to x1.fcnoip.org:18001
2018/12/30 17:01:37 00000000   >> OSCam <<  cardserver log switched, version 1.20_svn, build r11444 (mipsel-unknown-linux-gnu-libusb)
2018/12/30 17:01:37 21C99CFE p   (reader) w1.fcnoip.org [cccam] proxy initialized, server w1.fcnoip.org:15001
2018/12/30 17:01:37 68BAAD43 p   (reader) x1.fcnoip.org [cccam] proxy initialized, server x1.fcnoip.org:18001
2018/12/30 17:01:38 621B6683 p   (reader) mrsharing.net [cccam] proxy initialized, server mrsharing.net:43
2018/12/30 17:01:38 621B6683 p   (reader) mrsharing.net [cccam] disconnected: reason close
2018/12/30 17:01:40 6D32A593 p   (reader) uyduserver.micel.me [cccam] connect failed: Connection timed out
2018/12/30 17:01:40 6D32A593 p   (reader) uyduserver.micel.me [cccam] proxy initialized, server uyduserver.micel.me:12002
2018/12/30 17:01:45 5145B868 p   (reader) france.ztvnl.com [cccam] connecting to france.ztvnl.com:10001
2018/12/30 17:01:45 71B59086 p   (reader) 5.135.15.168 [cccam] connecting to 5.135.15.168:10004
2018/12/30 17:01:45 1825C741 p   (reader) b3.vipmgcamd.com [cccam] connecting to b3.vipmgcamd.com:2002
2018/12/30 17:01:45 39D8FD12 p   (reader) B3.vipmgcamd.com [cccam] connecting to B3.vipmgcamd.com:2002
2018/12/30 17:01:45 491FF909 p   (reader) b3.vipmgcamd.com [cccam] connecting to b3.vipmgcamd.com:2002
2018/12/30 17:01:45 3671E7F3 p   (reader) allcable.dremmer.com [cccam] connecting to allcable.dremmer.com:12050
2018/12/30 17:01:45 5A71E8F7 p   (reader) b3.vipmgcamd.com [cccam] connecting to b3.vipmgcamd.com:2002
2018/12/30 17:01:45 46F11045 p   (reader) france.ztvnl.com [cccam] connecting to france.ztvnl.com:10001
2018/12/30 17:01:45 7ACBFEC8 p   (reader) allcable.dremmer.com [cccam] connecting to allcable.dremmer.com:12050
2018/12/30 17:01:45 413BED11 p   (reader) b3.vipmgcamd.com [cccam] connecting to b3.vipmgcamd.com:2004
2018/12/30 17:01:45 2EDD72F7 p   (reader) lx76jo2x.xserver.su [cccam] connecting to lx76jo2x.xserver.su:1003
2018/12/30 17:01:45 22E9E634 p   (reader) handa.zapto.org [cccam] connecting to handa.zapto.org:12000
2018/12/30 17:01:45 71B59086 p   (reader) 5.135.15.168 [cccam] disconnected: reason close
2018/12/30 17:01:45 5145B868 p   (reader) france.ztvnl.com [cccam] disconnected: reason close
2018/12/30 17:01:45 1825C741 p   (reader) b3.vipmgcamd.com [cccam] disconnected: reason disconnect
2018/12/30 17:01:45 7ACBFEC8 p   (reader) allcable.dremmer.com [cccam] disconnected: reason disconnect
2018/12/30 17:01:45 3671E7F3 p   (reader) allcable.dremmer.com [cccam] disconnected: reason close
2018/12/30 17:01:45 46F11045 p   (reader) france.ztvnl.com [cccam] disconnected: reason close
2018/12/30 17:01:45 491FF909 p   (reader) b3.vipmgcamd.com [cccam] disconnected: reason close
2018/12/30 17:01:46 5530E78B p        (-) -- Skipped 2 duplicated log lines --
2018/12/30 17:01:46 5530E78B p   (reader) zes2.tjurk.com [cccam] connecting to zes2.tjurk.com:28900
2018/12/30 17:01:46 3521E2FF p   (reader) magicbox2017.com [cccam] connecting to magicbox2017.com:30000
2018/12/30 17:01:46 1FECBA8D p   (reader) france.ztvnl.com [cccam] connecting to france.ztvnl.com:10001
2018/12/30 17:01:46 7CE03EE2 p   (reader) ziggo3.ztvnl.com [cccam] connecting to ziggo3.ztvnl.com:10004
2018/12/30 17:01:46 6EDAB40B p   (reader) magicbox2017.com [cccam] connecting to magicbox2017.com:30000
2018/12/30 17:01:46 62898586 p   (reader) sumartv-fullhd.com [cccam] connecting to sumartv-fullhd.com:40000
2018/12/30 17:01:46 7DC0DD78 p   (reader) allcable.dremmer.com [cccam] connecting to allcable.dremmer.com:12050
2018/12/30 17:01:46 62898586 p    (cccam) init error from reader sumartv-fullhd.com
2018/12/30 17:01:46 1FECBA8D p   (reader) france.ztvnl.com [cccam] disconnected: reason close
2018/12/30 17:01:46 7CE03EE2 p   (reader) ziggo3.ztvnl.com [cccam] disconnected: reason close
2018/12/30 17:01:46 3521E2FF p   (reader) magicbox2017.com [cccam] disconnected: reason close
2018/12/30 17:01:46 7DC0DD78 p   (reader) allcable.dremmer.com [cccam] disconnected: reason close
2018/12/30 17:01:46 6EDAB40B p   (reader) magicbox2017.com [cccam] disconnected: reason close
2018/12/30 17:01:46 5530E78B p   (reader) zes2.tjurk.com [cccam] disconnected: reason close
2018/12/30 17:01:47 2BA97E90 p   (reader) 46.105.126.147 [cccam] connecting to 46.105.126.147:28900
2018/12/30 17:01:47 770552D4 p   (reader) B3.vipmgcamd.com [cccam] connecting to B3.vipmgcamd.com:2002
2018/12/30 17:01:47 770552D4 p   (reader) B3.vipmgcamd.com [cccam] disconnected: reason close
2018/12/30 17:01:47 2BA97E90 p   (reader) 46.105.126.147 [cccam] disconnected: reason close
2018/12/30 17:01:48 39D8FD12 p   (reader) B3.vipmgcamd.com [cccam] connect failed: Connection timed out
2018/12/30 17:01:48 6ACAD78E p   (reader) 80.151.174.117 [cccam] connecting to 80.151.174.117:12000
2018/12/30 17:01:48 71FA7529 p   (reader) 5.189.147.211 [cccam] connecting to 5.189.147.211:2002
2018/12/30 17:01:48 2BE49360 p   (reader) 129.242.32.203 [cccam] connecting to 129.242.32.203:12000
2018/12/30 17:01:48 24000104 p   (reader) mrsharing.net [cccam] connecting to mrsharing.net:43
2018/12/30 17:01:48 73E5F5ED p   (reader) b3.vipmgcamd.com [cccam] connecting to b3.vipmgcamd.com:2002
2018/12/30 17:01:48 335D7377 p   (reader) 1.tvsnake.com [cccam] connecting to 1.tvsnake.com:22500
2018/12/30 17:01:48 03EB2F23 p   (reader) server55.justcccam.info [cccam] connecting to server55.justcccam.info:22309
2018/12/30 17:01:48 29817EE3 p   (reader) 1.tvsnake.com [cccam] connecting to 1.tvsnake.com:22600
2018/12/30 17:01:48 2E0ABA97 p   (reader) pays.nopay0.com [cccam] connecting to pays.nopay0.com:12000
2018/12/30 17:01:48 73E5F5ED p   (reader) b3.vipmgcamd.com [cccam] disconnected: reason close
2018/12/30 17:01:49 5CC2E347 p   (reader) 1.tvsnake.com [cccam] connecting to 1.tvsnake.com:22500
2018/12/30 17:01:51 6ACAD78E p   (reader) 80.151.174.117 [cccam] connect failed: Connection timed out
2018/12/30 17:01:51 71FA7529 p   (reader) 5.189.147.211 [cccam] connect failed: Connection timed out
2018/12/30 17:01:51 2BE49360 p   (reader) 129.242.32.203 [cccam] connect failed: Connection timed out
2018/12/30 17:01:51 24000104 p   (reader) mrsharing.net [cccam] connect failed: Connection timed out
2018/12/30 17:01:51 335D7377 p   (reader) 1.tvsnake.com [cccam] connect failed: Connection timed out
2018/12/30 17:01:51 03EB2F23 p   (reader) server55.justcccam.info [cccam] connect failed: Connection timed out
2018/12/30 17:01:51 29817EE3 p   (reader) 1.tvsnake.com [cccam] connect failed: Connection timed out
2018/12/30 17:01:51 2E0ABA97 p   (reader) pays.nopay0.com [cccam] connect failed: Connection timed out
2018/12/30 17:01:51 621B6683 p   (reader) mrsharing.net [cccam] connecting to mrsharing.net:43
2018/12/30 17:01:52 5CC2E347 p   (reader) 1.tvsnake.com [cccam] connect failed: Connection timed out
2018/12/30 17:01:53 6D32A593 p   (reader) uyduserver.micel.me [cccam] connecting to uyduserver.micel.me:12002
2018/12/30 17:01:54 621B6683 p   (reader) mrsharing.net [cccam] connect failed: Connection timed out
2018/12/30 17:01:56 6D32A593 p   (reader) uyduserver.micel.me [cccam] connect failed: Connection timed out
2018/12/30 17:01:58 1825C741 p   (reader) b3.vipmgcamd.com [cccam] connecting to b3.vipmgcamd.com:2002
2018/12/30 17:01:58 5145B868 p   (reader) france.ztvnl.com [cccam] connecting to france.ztvnl.com:10001
2018/12/30 17:01:58 71B59086 p   (reader) 5.135.15.168 [cccam] connecting to 5.135.15.168:10004
2018/12/30 17:01:58 39D8FD12 p   (reader) B3.vipmgcamd.com [cccam] connecting to B3.vipmgcamd.com:2002
2018/12/30 17:01:58 491FF909 p   (reader) b3.vipmgcamd.com [cccam] connecting to b3.vipmgcamd.com:2002
2018/12/30 17:01:58 3671E7F3 p   (reader) allcable.dremmer.com [cccam] connecting to allcable.dremmer.com:12050
2018/12/30 17:01:58 46F11045 p   (reader) france.ztvnl.com [cccam] connecting to france.ztvnl.com:10001
2018/12/30 17:01:58 5A71E8F7 p   (reader) b3.vipmgcamd.com [cccam] connecting to b3.vipmgcamd.com:2002
2018/12/30 17:01:58 7ACBFEC8 p   (reader) allcable.dremmer.com [cccam] connecting to allcable.dremmer.com:12050
2018/12/30 17:01:58 2EDD72F7 p   (reader) lx76jo2x.xserver.su [cccam] connecting to lx76jo2x.xserver.su:1003
2018/12/30 17:01:58 413BED11 p   (reader) b3.vipmgcamd.com [cccam] connecting to b3.vipmgcamd.com:2004
2018/12/30 17:01:58 22E9E634 p   (reader) handa.zapto.org [cccam] connecting to handa.zapto.org:12000
2018/12/30 17:01:58 22E9E634 p   (reader) handa.zapto.org [cccam] connect failed: Connection refused
2018/12/30 17:01:58 2EDD72F7 p    (cccam) cccam(r) lx76jo2x.xserver.su: login failed, usr/pwd invalid
2018/12/30 17:01:58 3671E7F3 p   (reader) allcable.dremmer.com [cccam] disconnected: reason disconnect
2018/12/30 17:01:58 5145B868 p   (reader) france.ztvnl.com [cccam] disconnected: reason close
2018/12/30 17:01:58 71B59086 p   (reader) 5.135.15.168 [cccam] disconnected: reason close
2018/12/30 17:01:58 46F11045 p   (reader) france.ztvnl.com [cccam] disconnected: reason close
2018/12/30 17:01:58 413BED11 p   (reader) b3.vipmgcamd.com [cccam] disconnected: reason close
2018/12/30 17:01:58 7ACBFEC8 p        (-) -- Skipped 1 duplicated log lines --
2018/12/30 17:01:58 7ACBFEC8 p   (reader) allcable.dremmer.com [cccam] disconnected: reason close
2018/12/30 17:01:58 39D8FD12 p   (reader) B3.vipmgcamd.com [cccam] disconnected: reason close
switch log file
Bu şu demek oluyor bana göre(tabii) oscam çalışıyor ama server beni dışarı atıyor (herkes anlasın diyede kabaca yazdım) :confused:
23,484
D dad6403
Bence en iyisi yazılımın tvden alınanıdır,çünkü çalışan tvden alınır,ben DHde aynı model tvnin farklı donanıma sahip olduğunu da görmüştüm,yani adreslemeler farklı olabilir,aslında vestel neden böyle yola girmiş onu da anlamadım,çünkü tv yazılımı çok çeşitli,çok bildiğimden değil ama girdiğim ftp sitelerinden görmüştüm çeşitliliği,(o zamanlar tabii) yani sonu *.dcf ile biten yazılımlardı,mesela benim tv mb91 kartlı ve 6142.dcf liyken başka mb91 kartlı tv ise xxxx.dcf idi.
Şimdi bu yazdıklarıma itiraz gelebilir ama vestelin "standart yazılım" uygulamasını da hiç görmedim,diğer marka tvler de beni hiç ilgilendirmezler açıkçası,ama en azından mb9x kartlı tvlerin tümüne standart yazılım verilmeliydi,sanki "toplama tv" gibi duruyor televizyonlar,kötümü hayır değil,ama ..., ama işte :smile:
23,484
Kod:
>> OSCam <<  cardserver log switched at Sun Dec 30 22:31:13 2018
2018/12/30 21:31:13 3A05BA38 p    (cccam) cccam(r) lx76jo2x.xserver.su: login failed, usr/pwd invalid  <--- ŞİFRE HATALI DEDİ
YENİDEN DENEYECEĞİM
2018/12/30 21:31:13 00000000   >> OSCam <<  cardserver log switched, version 1.20_svn, build r11444 (mipsel-unknown-lin
2018/12/30 21:31:13 33D8FA69 p   (reader) B3.vipmgcamd.com [cccam] disconnected: reason close
EK:
Konuyu dışarıdan takip eden herkese:
Bu arada oscam usb bellekte çalışıyor,tv yazılımına müdahale edilmeden yani,bu konuyu geliştirmek gerekir,hep demişimdir "oscam hakkında bilgim yok" diye ,şimdilik sadece uygulama olarak çalışıyor ve herhangi bir hata vermedi...
Şimdilik müsadenizle kaçtım artık :bye
digiulama
5 Nis 2018
882
Bana şu usb bellekten çalışma sistemini atabilirmisin birde ben bakayım usb den çalışma sistemine ama şimdi değil 15 gün İstanbul dışındayım eve gidince bakabilirim anca :)
23,484
Kesinlikle veririm,ama senin tv arm,birkaç tane derlemem lazım arm için,acele etme birkaç gün bende yokum buralarda.
T tartar10 sende tvye telnetle bağlanıp işlemci mimarisini burada yazarsan sevinirim,büyük ihtimal arm'dır ama sen yine de bak.
Bunu toolbox ile bağlandıktan sonra konsoldan(veya cmd ile), diyelim tvnin ipsi 10.0.0.1 ,o zaman :
Kod:
telnet 10.0.0.1
yazıp enter bas,tv ye girince :
DÜZENLEME:
Sizin modellerde ve MB97 serisi tvlerde direkt /dev/shm içine giriyor hem ftp hem telnet,bu yüzden düzeltme yayınlama gereği duydum :)
telnetle tvye girince ÖNCE MUTLAKA :
Kod:
cd
komutunu verip entere bas ki kök dizinine girilmeli,kök dizininde aşağıdaki klasörleri de görmelisin:
Kod:
Customer        applications    certificate     database        font            lib             mnt             root            sys             usr
CustomerBackup  bin             conf            dev             home            linuxrc         opt             sbin            tmp             var
OAD             buffer          config          etc             init            lost+found      proc            subsystem       usb             vendor
yani bunları veya bu klasörlere benzeyenleri görürsen kök dizine girmişsin demektir.
işte şimdi aşağıdaki kodu vererek işlemi yapabilirsin(iz)
Kod:
cat /proc/cpuinfo
yazıp, entere bas,çıkan sonucun resmini çekip buraya ekle.kod içine yazdığım yazıyı kopyalayıp cmd ekranına yapıştırabilirsin :)
Ve evet aşağıda oscam USB üzerinden çalışması :smile:
Herkese:
Bu arada kendime bir süre mola vereceğim,
