Önemli Vestel - Hi-Level - Nexon - Seg - Telefunken Tv. Yazılım Modlama [ilk Mesaj Güncel]
bunu cnfige at turksat fx kanalına bak bide bağlantı için
tvip:8888
açtım onuda
bu var bende full değilmi yani bu
tvip:8888
açtım onuda
Buradaki webif dediği nedir,birde dvbapi de dreambox yazıyor işte hata orda bence,o apiyi tv veya aurora yapmak lazım belkide
Sn. @teraspy ve Sn. @digiulama, heyecan dorukta!
:) tv 2 kere reset attı aldığım log dosyaları da silindi birtek usbde kaldı,log dosyası
seçenekleri göstereyim dvbapide
Kod:
>> OSCam <<  cardserver log switched at Tue Dec 18 13:50:31 2018
2018/12/18 13:50:31 00000000 s   (reader) emulator [emu] creating thread for device emulator
2018/12/18 13:50:31 00000000   >> OSCam <<  cardserver log switched, version build-audi06_19-svn1.20, build r11431 (mipsel-unknown-linux-gnu)
2018/12/18 13:50:31 14CF2D4B r   (reader) emulator [emu] Reader initialized (device=emulator, detect=cd, mhz=357, cardmhz=357)
2018/12/18 13:50:31 00000000 s     (stat) loadbalancer: could not open /tmp/.oscam/stat for reading (errno=2 No such file or directory)
2018/12/18 13:50:31 00000000 s     (main) waiting for local card init
2018/12/18 13:50:32 5BC7046D p    (cccam) server1 configuration error!
2018/12/18 13:50:32 14CF2D4B r        (-) -- Skipped 1 duplicated log lines --
2018/12/18 13:50:32 14CF2D4B r   (reader) emulator [emu] card detected
2018/12/18 13:50:33 14CF2D4B r   (reader) emulator [emu] found card system emu
2018/12/18 13:50:33 14CF2D4B r   (reader) emulator [emu] THIS WAS A SUCCESSFUL START ATTEMPT No  1 out of max alloted of 1
2018/12/18 13:50:33 14CF2D4B r      (emu) Reading key file: /var/tuxbox/config/SoftCam.Key
2018/12/18 13:50:33 14CF2D4B r      (emu) Total keys in memory: W:0 V:13 N:9 I:7 S:2 F:208 P:506 D:0 T:5
2018/12/18 13:50:33 00000000 s     (main) init for all local cards done
2018/12/18 13:50:33 00000000 s (anticasc) anti cascading disabled
2018/12/18 13:50:33 7DEB1659 c   (client) plain dvbapi-client granted (dvbapiau, au=auto (6 reader))
2018/12/18 13:50:33 7DEB1659 c   (dvbapi) dvbapi channelcache loaded from /var/tuxbox/config/oscam.ccache
2018/12/18 13:50:33 7DEB1659 c   (dvbapi) ERROR: Could not detect DVBAPI version.
192.168.1.28:8888 aynı şekilde senin tv ip : 8888 yap bi bağlan oscama
Sn. @ [IMG]https://tavsiyeforumu.com/data/avatars/s/4/4273.jpg?1544480068[/IMG] @teraspy,
1. benim receiverda oscam'ın tam randımanlı çalışması için aşağıdaki 5 dosyaya ihtiyaç duyuluyor;
-Oscam binary (esas dosya)
-Oscam server (Kanalın şifresinin alınacağı adres)
-Oscam config (Oscam'ın çalışma prensibi)
-Oscam user (Oscam Serverda neler yapılacağını belirleyen kamut dosyası)
-Oscam dvbapi (şifreli kanalların caid ve providerlarının yer aldığı dosya)
2. Bunların dışında ayrıca, config dosyasının içinde oscam'ın ilk hareketini (çalışmasını) başlatan bir dosya ve
3. İşlemci ile oscam iletişimini sağlayan lib dosyası var.
Samsung tv'de oscam'ın çalışma mantığını anlamada belki bu dosyalar işinize yarayabilir.
zaten verdiğim resimde rahat düzenlersin yeterki bağlantı kurulsun tv ile pc arası gerisi çorap söküğü gibi gelir
Kod:
>> OSCam <<  cardserver log switched at Tue Dec 18 13:17:44 2018
2018/12/18 13:17:44 00000000 s >> OSCam <<  cardserver log switched, version build-audi06_19-svn1.20, build r11431 (mipsel-unknown-linux-gnu)
2018/12/18 13:17:44 00000000 s     (main) System name    = Linux
2018/12/18 13:17:44 00000000 s     (main) Host name      = (none)
2018/12/18 13:17:44 00000000 s     (main) Release        = 2.6.28.10
2018/12/18 13:17:44 00000000 s     (main) Version        = #59 PREEMPT Fri Nov 21 18:11:04 EET 2014
2018/12/18 13:17:44 00000000 s     (main) Machine        = mips
2018/12/18 13:17:44 00000000 s     (main) creating pidfile /tmp/.oscam/oscam.pid with pid 589
2018/12/18 13:17:44 00000000 s   (config) services reloaded: 0 services freed, 27 services loaded, rejected 0
2018/12/18 13:17:44 00000000 s      (emu) OSCam-Emu version 772
2018/12/18 13:17:44 00000000 s   (config) userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
2018/12/18 13:17:44 00000000 s     (main) signal handling initialized
2018/12/18 13:17:44 00000000 s   (config) 924 provid's loaded
2018/12/18 13:17:44 00000000 s   (config) 24 service-id's loaded in 1 ms
2018/12/18 13:17:44 539AD822 h    (webif) webif: decompressed 178899 bytes back into 441784 bytes
2018/12/18 13:17:44 539AD822 h    (webif) HTTP Server running. ip=0.0.0.0 port=8888
2018/12/18 13:17:44 00000000 s   (reader) server1 [cccam] creating thread for device host
2018/12/18 13:17:44 02A5F996 p    (cccam) server1 configuration error!      <----------------------  SERVER HATASI
2018/12/18 13:17:44 02A5F996 p   (reader) server1 [cccam] proxy initialized, server host:0
2018/12/18 13:17:44 00000000 s   (reader) emulator [emu] creating thread for device emulator
2018/12/18 13:17:44 0CE6FAE5 r   (reader) emulator [emu] Reader initialized (device=emulator, detect=cd, mhz=357, cardmhz=357)
2018/12/18 13:17:44 00000000 s     (stat) loadbalancer: could not open /tmp/.oscam/stat for reading (errno=2 No such file or directory)
2018/12/18 13:17:44 00000000 s     (main) waiting for local card init
2018/12/18 13:17:45 02A5F996 p    (cccam) server1 configuration error!
2018/12/18 13:17:45 0CE6FAE5 r        (-) -- Skipped 1 duplicated log lines --
2018/12/18 13:17:45 0CE6FAE5 r   (reader) emulator [emu] card detected  :)
2018/12/18 13:17:46 0CE6FAE5 r   (reader) emulator [emu] found card system emu    :)
2018/12/18 13:17:46 0CE6FAE5 r   (reader) emulator [emu] THIS WAS A SUCCESSFUL START ATTEMPT No  1 out of max alloted of 1
2018/12/18 13:17:47 0CE6FAE5 r      (emu) Reading key file: /var/tuxbox/config/SoftCam.Key    :))))))
2018/12/18 13:17:47 0CE6FAE5 r      (emu) Total keys in memory: W:0 V:13 N:9 I:7 S:2 F:208 P:506 D:0 T:5    :))))
2018/12/18 13:17:47 00000000 s     (main) init for all local cards done
2018/12/18 13:17:47 00000000 s (anticasc) anti cascading disabled
2018/12/18 13:17:47 67657F00 c   (client) plain dvbapi-client granted (dvbapiau, au=auto (6 reader))
2018/12/18 13:17:47 67657F00 c   (dvbapi) dvbapi channelcache loaded from /var/tuxbox/config/oscam.ccache
bir yerde var hata,ama nerede ,ilki zaten dvbapide ,server önemli değil ,senin resindeki liste nereden geliyor,veya sen nereden aldın bu listeyi?
Bunlar var bende zaten,ama benim mimari Mips ,gerçi önemli değil,mantık aynı,mips ile arm ...birde ben farklı yerden indirdim linuxsa kurdum,fakat çalışma mantığını anlamıyorum bu oscamın :=)
açtım programı benim pc ye gir istersen ordan oscamı incele hiç ayar yapmadım şuan direk attım test cihazına ordan sıkıntısız kurcala o yolladıgım resimdekileri ayrıntısına kadar görürsün
Kod:
Söylemeye çalıştığım, oscam ve işlemci arasında bağ kuracak bir komut gerekiyor. Buda sanırım lib dosyası. Bu lib dosyasını Samsung tv'ninkinden uyarlayamaz mıyız?
arm7 ise tv ben attım burdan onu indirebilirsin ama bir yerde donuyor 10 dk gibi
Ben linux kullanıyorum,senin pcye giremem büyük ihtimalle,ama inan çok teşekkür ederim,bunu yazman bile benim için bir devlet.oscamı sistemde derlemeye çalışacağım bakalım,gerekli programı indirmiştim.
lib dosyasından dolayı hata verseydi eğer program belirtirdi xxxxxxx.so" bulunamadı diye,ama elimin altında duruyor libler.
donar, çünkü sendeki program hatalı,tv için değil o sanırım
bu benim oscam log,ip 0 görünüyor,bunu ellemi değiştireceğiz acaba ?
oscam config varya sana verdiğim ordan yada senin attığın bir dosya içinde webif varmı varsada ordan 8888 yap ki giresin resimdeki gibi
