Telefunken 24550s27yxd
yokoono Çevrimdışı
1. The TV model mentioned in the topic ( 24550s27yxd) does not exist. It takes the right model.
2. The panel code (VESxxxxxxxx) is also needed.
3. You did not say what values you found at VGH and VGL
4. If the panel is defective, the re-software is useless.
5. How did the defect occur? Have you tried rewriting the software?
6. You said the image is white. How did you type menu1505?. Without seeing?
ralph65 Çevrimdışı
ralph65
27 Nis 2021
60
PSU 17ipds615 telefunken te24550s27yxd
Main. 17mb140
LCD ves236wnvh You need the USB file for lcd panels ves236wnvh. Can you help me? Thank you.
yokoono Çevrimdışı
I have software for VES236WNTB-2D-N02, VES236WNVB-2D-N11 (spi), VES236WNVB-2D-N13, VES236WNVC-2D-N01, VES236WNVC-2D-N12 (usb+spi).
For 17MB140 and VES236WNVH panel I have bin for 25Q128 flash memory. It's from a TV called OK. It is written with a programmer. I don't have for usb.
ralph65 Çevrimdışı
ralph65
27 Nis 2021
60
Ves
Ves236wnvh - 2D-N21 I have ch341a programmer. Help me.
Can you send me files for 25Q128 ves236wnvh 2D-N21 ? Thank you.
ralph65 Çevrimdışı
ralph65
27 Nis 2021
60
Guys I put toshiba firmware with the same panel. Now there is no audio and it does not respond to the remote. I would like to bring it back to how it was before if possible. I'm looking for a recovery USB file. Can you help me? Thank you.
hosbulduk Çevrimdışı
hosbulduk
9 Kas 2018
3,721
If you install Toshiba software on a Telefunken TV, there may be a remote control issue as it is incompatible. If possible, try to find a Toshiba remote control or use phone applications to control the TV.
ralph65 Çevrimdışı
ralph65
27 Nis 2021
60
ok now the remote goes. i would like to bring it back as telefunken to find me with its remote is it possible?
