- 20 Mar 2019
- 3,236
- 74
1. The TV model mentioned in the topic ( 24550s27yxd) does not exist. It takes the right model.
2. The panel code (VESxxxxxxxx) is also needed.
3. You did not say what values you found at VGH and VGL
4. If the panel is defective, the re-software is useless.
5. How did the defect occur? Have you tried rewriting the software?
6. You said the image is white. How did you type menu1505?. Without seeing?
