here we go again for the newer mb2xx boards
TommyData
13 May 2018
50
  • 2021/02/09 16:01:36 1E65D522 c (dvbapi) ERROR: Could not detect DVBAPI version.
  • Das ist das Problem
Crosscompiler hab ich jetzt - wir können oscam nun also selber compilieren
hosbulduk Çevrimdışı
hosbulduk
9 Kas 2018
3,721
Wenn am Anfang nicht dvbapi ausgewählt ist, wird diese Warnung nicht angezeigt. Im Internet gab es Informationen diese Option nur für den Kartenleser.
hosbulduk
9 Kas 2018
3,721
bei mir dvbapi ist jetzt so...Ich habe derzeit keinen aktiven Server .
2021/02/09 18:28:26 00000000 s >> OSCam << cardserver log switched, version 1.20_svn, build r11684-798 (arm-v7a8v3r1-linux-gnueabi)
2021/02/09 18:28:26 00000000 s (main) System name = Linux
2021/02/09 18:28:26 00000000 s (main) Host name = (none)
2021/02/09 18:28:26 00000000 s (main) Release = 3.10.40
2021/02/09 18:28:26 00000000 s (main) Version = #7 SMP PREEMPT Tue Oct 4 14:35:30 CST 2016
2021/02/09 18:28:26 00000000 s (main) Machine = armv7l
2021/02/09 18:28:26 00000000 s (main) creating pidfile /tmp/.oscam/oscam.pid with pid 22651
2021/02/09 18:28:26 00000000 s (config) services reloaded: 0 services freed, 40 services loaded, rejected 0
2021/02/09 18:28:26 00000000 s (emu) OSCam-Emu version 798
2021/02/09 18:28:26 00000000 s (config) userdb reloaded: 6 accounts loaded, 0 expired, 3 disabled
2021/02/09 18:28:26 00000000 s (main) signal handling initialized
2021/02/09 18:28:26 00000000 s (config) 67 provid's loaded
2021/02/09 18:28:26 00000000 s (config) 20 tier-id's loaded
2021/02/09 18:28:26 00000000 s (net) monitor: initialized (fd=34, port=998)
2021/02/09 18:28:26 00000000 s (net) cccam: initialized (fd=36, port=20000)
2021/02/09 18:28:26 00000000 s (reader) emulator [emu] creating thread for device emulator
2021/02/09 18:28:26 00000000 s (reader) CCcam [cccam] creating thread for device none
2021/02/09 18:28:26 00000000 s (main) waiting for local card init
2021/02/09 18:28:26 31EC86F9 p (cccam) CCcam configuration error!
2021/02/09 18:28:26 31EC86F9 p (reader) CCcam [cccam] proxy initialized, server none:0
2021/02/09 18:28:26 4AD3B853 r (emu) Stream key delayer initialized
2021/02/09 18:28:26 4AD3B853 r (emu) Stream relay server initialized
2021/02/09 18:28:26 4AD3B853 r (reader) emulator [emu] Reader initialized (device=emulator, detect=cd, mhz=357, cardmhz=357)
2021/02/09 18:28:26 6B65484E h (webif) webif: decompressed 185565 bytes back into 490816 bytes
2021/02/09 18:28:26 6B65484E h (webif) HTTP Server running. ip=0.0.0.0 port=8888
2021/02/09 18:28:26 00000000 (emu) INFO: FFDecsa parallel mode = 32
2021/02/09 18:28:27 4AD3B853 r (reader) emulator [emu] card detected
2021/02/09 18:28:28 4AD3B853 r (reader) emulator [emu] found card system emu
2021/02/09 18:28:28 4AD3B853 r (reader) emulator [emu] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max allotted of 1
2021/02/09 18:28:28 4AD3B853 r (emu) Reading key file: /mnt/hd0a/tuxbox/config/SoftCam.Key
2021/02/09 18:28:28 4AD3B853 r (emu) Total keys in memory: W:0 V:22 N:9 I:7 F:212 G:0 P:884 T:30 A:0
2021/02/09 18:28:29 00000000 s (main) init for all local cards done
2021/02/09 18:28:29 00000000 s (emmcache) loaded 0 emmcache records from /tmp/.oscam/oscam.emmcache in 0 ms
2021/02/09 18:28:29 00000000 s (emmcache) loaded 0 emmstat records from /tmp/.oscam/oscam.emmstat in 0 ms
2021/02/09 18:28:29 3022AC51 c (client) plain dvbapi-client granted (dvbapiau, au=auto (9 reader))
2021/02/09 18:28:29 3022AC51 c (dvbapi) dvbapi channelcache loaded from /mnt/hd0a/tuxbox/config/oscam.ccache
2021/02/09 18:28:29 3022AC51 c (dvbapi) Using /tmp/camd.socket listen socket, API forced to DVBAPIv3 (0), userconfig boxtype: 11
hosbulduk
9 Kas 2018
3,721
kendisi oscam toolchain hazirlamis vestel icin yanlis anlamadiysam ama dvbapi hazir degil ve bendeki gibi tv de görüntü simdilik yok..dvbapi ile ugrasan oldu mu diye sordu ilk önce, dvbapi sürümü tespit edilemedi uyarisi sorunu var dedi.ben görüntü icin sizin usb den birseyler yapilmasi gerektigini söylediginizi yazdim.monitör ile ilgili nette birsey bulmustum onu paylastim,ocscam.conf ve user bilgilerini eklendikten sonra tv de görüntü aldigini yazmislardi..
Birde script buldum ama ne ise yaradigini cözebilmis degilim henüz,tv icine girince bin dosyasina girmeden komut verip oscam i calistirabiliyorum bu komuttan sonra.
#!/bin/sh
CAMNAME="oscam.bin"
remove_tmp () {
rm -rf /tmp/*.info* /tmp/*.tmp*
case "$1" in
start)
echo "[SCRIPT] $1: $CAMNAME"
remove_tmp
/bin/oscam -b -c /mnt/hd0a/tuxbox/config/oscam
stop)
killall -9 oscam >/dev/null
sleep 1
remove_tmp
$0 stop
exit 0
esac
exit 0
23,425
#!/bin/sh
CAMNAME="oscam.bin"
remove_tmp () {
case "$1" in
start)
remove_tmp
stop)
sleep 1
remove_tmp
$0 stop
exit 0
esac
exit 0
Buna gerek yok ,rcS içine eklersen tv her açılışta otomtik çalışır oscam (bende öyle idi) :ok
Oscam dvbapi gerekli tabii ama görüntü alma olayını anlamadım,şifreli kanal görüntüsü mü :alala
hosbulduk
9 Kas 2018
3,721
Buradan ne anlamam gerekiyor cunki burada dvbapi uyarısı yok..
  • 2021/02/09 23:41:59 00000000 s (main) System name = Linux
  • 2021/02/09 23:41:59 00000000 s (main) Host name = (none)
  • 2021/02/09 23:41:59 00000000 s (main) Release = 3.10.40
  • 2021/02/09 23:41:59 00000000 s (main) Version = #7 SMP PREEMPT Tue Oct 4 14:35:30 CST 2016
  • 2021/02/09 23:41:59 00000000 s (main) Machine = armv7l
  • 2021/02/09 23:41:59 00000000 s (main) creating pidfile /tmp/.oscam/oscam.pid with pid 12885
  • 2021/02/09 23:41:59 00000000 s (config) services reloaded: 0 services freed, 40 services loaded, rejected 0
  • 2021/02/09 23:41:59 00000000 s (emu) OSCam-Emu version 798
  • 2021/02/09 23:41:59 00000000 s (config) userdb reloaded: 6 accounts loaded, 0 expired, 4 disabled
  • 2021/02/09 23:41:59 00000000 s (main) signal handling initialized
  • 2021/02/09 23:41:59 00000000 s (config) 67 provid's loaded
  • 2021/02/09 23:41:59 00000000 s (config) 20 tier-id's loaded
  • 2021/02/09 23:41:59 00000000 s (net) monitor: initialized (fd=34, port=998)
  • 2021/02/09 23:41:59 00000000 s (net) cccam: initialized (fd=36, port=20000)
  • 2021/02/09 23:41:59 00000000 s (reader) CCcamPrime [cccam] creating thread for device s1.cccamprime.com
  • 2021/02/09 23:41:59 00000000 s (reader) emulator [emu] creating thread for device emulator
  • 2021/02/09 23:41:59 00000000 s (main) waiting for local card init
  • 2021/02/09 23:41:59 4D9ABF7F r (emu) Stream key delayer initialized
  • 2021/02/09 23:41:59 3B7EE883 h (webif) webif: decompressed 185565 bytes back into 490816 bytes
  • 2021/02/09 23:41:59 3B7EE883 h (webif) HTTP Server running. ip=0.0.0.0 port=8888
  • 2021/02/09 23:41:59 4D9ABF7F r (emu) Stream relay server initialized
  • 2021/02/09 23:41:59 4D9ABF7F r (reader) emulator [emu] Reader initialized (device=emulator, detect=cd, mhz=357, cardmhz=357)
  • 2021/02/09 23:41:59 00000000 (emu) INFO: FFDecsa parallel mode = 32
  • 2021/02/09 23:41:59 42569D35 p (reader) s1.cccamprime.com: resolved ip=207.180.238.178
  • 2021/02/09 23:41:59 42569D35 p (reader) CCcamPrime [cccam] connecting to s1.cccamprime.com:13008
  • 2021/02/09 23:42:00 42569D35 p (reader) CCcamPrime [cccam] proxy initialized, server s1.cccamprime.com:13008
  • 2021/02/09 23:42:00 4D9ABF7F r (reader) emulator [emu] card detected
  • 2021/02/09 23:42:01 4D9ABF7F r (reader) emulator [emu] found card system emu
  • 2021/02/09 23:42:01 4D9ABF7F r (reader) emulator [emu] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max allotted of 1
  • 2021/02/09 23:42:01 4D9ABF7F r (emu) Reading key file: /mnt/hd0a/tuxbox/config/SoftCam.Key
  • 2021/02/09 23:42:01 4D9ABF7F r (emu) Total keys in memory: W:0 V:22 N:9 I:7 F:212 G:0 P:884 T:30 A:0
  • 2021/02/09 23:42:02 00000000 s (main) init for all local cards done
  • 2021/02/09 23:42:02 00000000 s (emmcache) loaded 0 emmcache records from /tmp/.oscam/oscam.emmcache in 1 ms
  • 2021/02/09 23:42:02 00000000 s (emmcache) loaded 0 emmstat records from /tmp/.oscam/oscam.emmstat in 0 ms
  • 2021/02/09 23:42:02 75192724 c (client) plain dvbapi-client granted (dvbapiau, au=auto (8 reader))
  • 2021/02/09 23:42:02 75192724 c (dvbapi) dvbapi channelcache loaded from /mnt/hd0a/tuxbox/config/oscam.ccache
  • 2021/02/09 23:42:02 75192724 c (dvbapi) Using /tmp/camd.socket listen socket, API forced to DVBAPIv3 (0), userconfig boxtype: 11
