ves430undb-2d-n12 sorry
Panel profile. Folder pq, menu 4725, usb operatios, ok, return etc.
no sucess with this maybe goes wrong with hw profile?
Do you know the installation procedure?
After copying the profile to the TV, exit the menu and turn off the TV. Wait until the stby LED stops flashing. Unplug the TV and wait until the stby LED goes out. You take out the stick and turn on the TV.
@By_Trol,
https://resim.tavsiyeforumu.com/images/WhatsApp-Image-2023-01-13-at-15.43.16814a66a1f90e5bd0.jpg[/im
PABEL YAZILIMI LAZIM ÖNCEKİ MB 96 YENİ TAKTIĞIM MB82 YARCIMCI OLURSANIZ SEVİNİRİM SAYGILAR KOLAY GELSİN.
@By_Trol,
Eklediğiniz resim görünmüyor.
Yes i did but no difference do you have any software ?
it will make problem to the board the software ?can you explain again the pq folder i have to put the ptf and ptc inside the folder?
FOR PANEL PROFILE
1. Format a stick (max. 8Gb) with FAT32
2. Create a folder called pq
3. Unzip and put the 2 files IN the pq folder
4. Turn on the TV and insert the USB stick
5. Type MENU and 4725
6. Go to USB Operations and type OK
7. Wait 10 seconds and press EXIT (RETURN) to exit the menu
8. Turn off the TV from the remote control and wait until the stby LED stops flashing
9. Unplug the TV and wait until the stby light goes out.
10. Take out the stick and turn on the TV
If you have 17MB211S in your TV, not 17MB211 as you wrote, you also have the panel profile here
FOR PANEL PROFILE
the software will make ?or will corrupt the board?
SEG 32SCH5620 10110296[1710]700613 SN:7902209700613 VPAZ:20273315 PNL:23452299
Merhaba arkadaşlar, yukarıda bilgileri tv main boardu 17MB140 yazılım almıyor,
Elimde 17MB82S main var 24" tv den çıkma; çalışıyor görüntü negatif, uygun panel yazılımı için yardımcı olur musunuz
bunu hiçbir yerden bulamıyorum yardımcı olurmusunuz
