1. The panel code is printed on a white label inside the TV. I did not write 3VES90. I wrote VES390.
2. I have modified the posted profile. Try it.
MB9X ailesi için;
Sorry for delay. But this didnt work.
Cod panel (VES390xxxx-xx-xx) ???.
The only white label on panel is this. And its V390HJ1-LE1. T-con board have same label. Is that what we are looking for?
OK. It's an INNOLUX panel, not Vestel. I'm trying to find a full software. The chances are pretty slim.
L.E.
I have this panel profile in my archive. Maybe you'll get lucky.
Panel profile:
L.E.
Panel profile:
i dont have any luck today :( . This didnt work. i change jeida to vesa it not worked too.I know I've kept you busy, but can you give full software ?
I searched. Unfortunately I don't have anything in the full soft archive for the 17MB95 main and V390HJ1-LE1 panel.
Full software. If you want to try, try at your own risk.
I'm letting you know that 17MB95 motherboards are very easy to brick.
bildirim çanından yazılıma ulaşabilirsin yükledikten sonra sonucu yazın
İlginiz için teşekkurler. Eski haline döndü.Çalışıyor. Emeğinize sağlık
Bu arada youtube açmıyor
40fd 7300 17mb 211s ful yazılım için yardımcı olur musunuz seri no:"8288275900855
