Hi all!
Looking for the full firm of Jvc-Lt50k880,17mb130s,ves500qndc-2d-n14
(img) /pic.twitter.com/images/20230824_165246.jpg[/img]
Lütfen görseli foruma ekleyiniz. TV' deki problemi detaylı olarak yazınız.
Disk genius programı ile usb belleği kontrol edin. Boot sektörü GPT ise MBR' ye çevirdikten sonra tekrar FAT32 formatlayın. Dosyaları atıp deneyin.
Bir de USB 3.0 destekli bir bellek kullanmamaya çalışın. 16 GB' tan büyük olmasın
çok uğraştım ama gpt mbr dönüşümü yapamadım malesef başka öneriniz var mı?
Hi all!
Tv powers on,backlight on, but no picture or sound and keeps stby led keeps blinking.
Thanks in advance!!
(img) /pic.twitter.com/images/20230824_1652465d9ef78e8866c909.jpg[/img]
Yazılımdan değil, lvds bağlantısı ya da anakartta donanım arızasından kaynaklandığını düşünüyorum. Her ihtimale karşı;
yokoono Master.
I think it's not from software but from lvds connection or hardware failure on motherboard. just in case;
yokoono Master.
well i tried and i I found a firmware of Hitachi for 49NDC-2D which works. I updated the panel with PQ files but... while everything is working - channels, YouTube, internet - the Netflix app, when loading, keeps showing the UI-800-3 (104001) error.
So i thought the problem with netflix could be solved if i had the correct firmware.
Şimdi tek problem Netflix hatası mıdır?
I have the software below in the archive. The problem is that after QNDC-2D the termination is missing. If you want, you can try it on your own. If there are problems with the image, I saw that you have a panel profile.
Thank you very much!I ll try and i will inform for future users!
unfortunately has the same problem.Everything working perfect except Netflix.
I think it needs it s firmware only.
Thanks anyway for your effort!
In another forum i found a firmware that Yokoono had sent a firmware for a jvc 55k880 but with VES550QNDL-2D-N11.
The link for this firmware has expaired.Is there any chance that still have it and give a try?
I am convinced that the motherboard has a hardware problem, not a software one.
If you want
Yes it could but is just that it only makes problem to Netflix app,which start normally with loading circle and after that say that it can t be connected and shows that error ui-803-3
çok sağolun
merhaba tekrardan dediğiniz şekilde yükledim attığınız linki ancak 6 dk olmasına rağmen hızlı hızlı yanıp sönmeye devam ediyor
Sota,
https://tavsiyeforumu.com/konu/hilevel-49hl550-tv-acilmiyor.7194/
buradan indirmiş olmam lazım
Bu arada yazılım isteklerinizi ana yazılım konularından yapmaya dikkat edin.
Panel yazılımını yüklediniz mi? sonuç nedir?
