yokoono Çevrimiçi
Hello.
We have a TV that is stuck on boot, only blinking red. The backlight is turning on but the TV is not booting up properly. I've attached the picture of the backside and the mainboard in the post below. Thank you in advance for the help.
Regards, Norbert.
Cod panel (VES550xxxxxxxx) ?.
N Çevrimdışı
norbiszoke
30 May 2018
20
I only have bin for rewriting flash memory with programmer.
Just rewriting the 25L160 will solve the stuck issue? Will try it in a minute and will reply with the result.
The TV is still doing the same as before. While truning it on after soldering back to flash to the board the set turned on for around half a minute and then rebooted, but still no image. The set after reboot is still stuck at turning on, while the red is blinking sadly.
G Çevrimdışı
gcicek
16 Ağu 2022
Merhaba,
SEG marka TV açılıyor ancak görüntü ve ses gelmiyor. SEG yazısı beliriyor sonra kayboluyor. Yardım edebilir misiniz?
Teşekkürler
yokoono Çevrimiçi
It means that the boot sequence has been altered. You will have to rewrite the NAND memory with the dedicated software. Unfortunately, I do not have.
N Çevrimdışı
norbiszoke
30 May 2018
20
So with the core update I wont be able re rewive the TV from its grave, only by rewriting the NAND can the TV work again?
So with the core update I wont be able to rewive the TV from its grave, only by rewriting the NAND can the TV work again?
The core update wont even start on the set... It just blinks on the pendrive 2-3 times and the set proceeds to be stuck in boot.
N Çevrimdışı
norbiszoke
30 May 2018
20
Got the TV working again with a full software that I found on another forum. The problem is now only the PANEL file. 23455852 is the panel that I need and the file that I have in the firmware is 23471158. Maybe someone has this panel file for upload into the mainboard via usb. I'm trying the files that I found on this forum, but for now I'm not getting 'clear' picture yet.
Edit: Tried flashing back the file that you posted a while back and still the same. Probably the panel file is in the NAND and not in the SPI IC.
yokoono Çevrimiçi
Panel profile:
N Çevrimdışı
norbiszoke
30 May 2018
20
Panel profile:
The panel file worked for the TV, but my picture is still with verical stripes. I had the same kind of picture like with this panel file. If I list the file that is ending with TMG with a txt editor then i can see that the panel name is a VES490QNEL, but that is probably fine. I might have a panel defect on this set because of the vertical stripes on the panel... On the left side i have like colored/blackish lines that are running through vertically from the left to the right side but as it goes futher right the lines are getting washed out and its barely visible.
Edit: As you can see on the screen the backlight is bad on this set, and I think that the problem with the stripes is because of the backlight problem. On the parts of the screen where the backlight is purple/bluish the stripes are way more pronounced and on the bottom right part of the screen where the backlight is almost perfectly white the stripes are gone. My assumption is that as the panel is polarizing/making the image the purple/blue light that is comming from the backlight is making it so that some stripes are becoming visible. Thank you for the kind help that you are providing me.
For now I think the TV is going back to it's owner, and if he's willing to pay the money for the backlight change then we will see if my assumption is right or wrong.
Regards, Norbert.
Regards, Norbert.
Edit2: I've attached a macro shot of the panel, and I think my assumption is 99% accurate now. You can see the colored pixels in the row's and the stripe with the color of the backlight.
Hasan70
3 Ara 2019
8
39
Merhaba
Hi-Level 49UHL650
Wireless Display problemi için eski yazılım full sürüm arıyorum. Tv bilgileri aşağıdaki şekilde. MB130 anakart sondan bir önceki yazılım olursa sevinirim. Kolay gelsin.
Selamlar, yardımcı olabilirseniz çok memnun olurum. Ürünün bu özelliği benim için çok faydalıydı.
N Çevrimdışı
nasmi.gr
31 Eki 2021
89
55
Merhaba Arkadaslar.
Ekte resimlerini gonderdigim TV nin yazilimi lazim.
TV normal calisiyor, calisirken bazen Test moduna geciyor. Ekran da Kirmizi, Yesil, Mavi, Beyaz Renlkler donusumlu olarak geciyor. fisi cikarip takinca Yine normal calisiyor. belli bir sure sonra yine ayni durum oluyor.
Yazilimdan olabilir diye dusundum.
Ilgili arkadaslar Yardimci olabilirler mi?
Simiden Herkese Tesekkurler...
Merhaba Arkadaslar.
Lvds kablosunu her iki taraftanda çıkartıp geri takın
