hayırlıs olsun,
samsung va panel, mb130p, hdr10, wcg
Tesekkur ederim üründen memnun kaldım beni şaşırtan babamlara 55ud9300 tv aldik o da samsung va panel 1800hz fakat 9400 un renkleri kadar basarili değil ve ekran karanlık sanki içindeki ledler in bir kısmı çalışmıyor renkler bir garip parlaklığı açsam da ekran bir tuhaf oluyor ama 9400 oldukça net ve güzel renkler sunuyor
Arkadashlar Selam!
Problem: Damaged edge backlight, mainly in TV's Finlux 50 ". I have already repaired dozens of such TV's.Damage identical in all..
I have a few questions:
What function do the elements marked" normal ". Is there known cause of damage only diode no.55.
@Wojtek,
As far as I know, the thermal fuse is used against the possibility of a fire, as there is a lot of transparent plexi (lgp) inside the led bar panel.
LED bar is very hot and open circuit. Therefore the power card to protect the led voltage is disconnecting
@teknovest, So the element that I marked this thermal fuse? Can You explain to me why in dozens of TV's it damages only this one and not three others on the belt.
The driver in SPU is also damaged.In new strings this element is skipped.Of course, the driver is damaged because the diode No.55 is destroyed.And in each case only this diode.I think that the thermal conditions for the entire backlight are almost the same.Why this one?Statistically, it's amazing regularity!The problem so far has occurred in me in around 200 sets
@Wojtek,
This problem occurs because the backlight is used at a high level, though this level of boredom will not be moderate.
@teknovest,
I am grateful for Your answer but I still do not know anything.
"It's good to know than to remain ignorant"-mine
tesekkurler!
seri numarası olmadan kontrol edemiyorum
Anlıyorum peki teşekkür ederim ürünleri alamadığım için seri numaram yok neyse bayiden rica ederim eğer verirse seri numarasını yazarım.
merhabalar, 8082346 800258 Televizyonun paneli IPS panel mi yoksa VA panel mi?
Toshiba 49" 49L2863DAT Rica etsem, bu tvnin hangi panel oldugu hakkında yardımcı olabilir misiniz? Burada yardımcı olunabilir diye buraya yazdım :)
Merhabalar, televizyonun bozulduğu için uygun fiyata televizyon arıyorum.
Televizyonun S N: 8082346 800258
Televizyonun anakartı nedir?
Televizyon IPS panel mi yoksa VA panel midir?
