Harika bir anlatım olmuş,ellerine sağlık kardeş
I think you will have to unpack your TV and post what your motherboard has and what panel.
If you need a programmer (CH341A) to rewrite the flash or eeprom?
anakart üzerindeki yazıt 17MB95-2.1 The inscription on the motherboard is 17MB95-2.1
And the panel ?.
The software should have a main /panel/power pair.
Do you have a CH341a programmer?
regal 50 r 7520 çekirdek yazılımı var mıdır nerden temin ederim
ustalara teşekkürler
teşekkürler
okey
For the stick. Can go. It is for main 17MB95S-1 and VES315WNDL-01.
For rewriting SPI 25L1606E memory. It's exactly what you need.
I put first soft to my usb stick, power off tv, plug in stick, press ok button on remote and plug power cable - TV turn on backlight, nothing can see on screen but change - power led is off. If i stop press ok button, after moment TV reboots and then power led is blinking. What i'm doing wrong?
1. Press and hold the OK button on the remote control and insert the TV into the socket.
2. Release the OK key after approx. 10-20 sec. or when the light stb. blinks fast.
3. Wait until the TV starts with the image or reboots or the stb LED stops flashing. Be sure to drink a beer until it resets.:mutlu
Merhaba uygun sürüm bumudur acaba ? (17MB96 - MB91R3 - MB92R4 3.7.6.L ) Bumu yoksa ( 17MB91R3_MB92R4_MB96_FAZ3_V376n) bumu
